damm raditor fan
mine wouldnt turn on either so i mounted a toggle switch above my shifter. run a power wire from the battery to one of the prongs on the toggle switch, be sure to put a 10 amp in line fuse with that wire. then run a wire from the other prong to the radiator fan. There will be a plug with a blue wire and black, unplug it. Now take the wire you just ran and put a female connector on it and plug it into the prong for the blue wire. Take another wire, put a female connector on it, plug it in to the prong with the black wire, and ground the other end.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lsweez »</TD></TR><TR><TD CLASS="quote">does anyone know how to jump out the raditor fan so that it would run, cause its not running and causing the car to over heat</TD></TR></TABLE>
Just buy a new thermo switch. Its only $20
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95TYPEGSR »</TD></TR><TR><TD CLASS="quote">mine wouldnt turn on either so i mounted a toggle switch above my shifter. run a power wire from the battery to one of the prongs on the toggle switch, be sure to put a 10 amp in line fuse with that wire. then run a wire from the other prong to the radiator fan. There will be a plug with a blue wire and black, unplug it. Now take the wire you just ran and put a female connector on it and plug it into the prong for the blue wire. Take another wire, put a female connector on it, plug it in to the prong with the black wire, and ground the other end.</TD></TR></TABLE>
is this h-t or is this "how to rig ur honda/acura"------
FMIDRC Racer
Aug 27, 2005 12:22 PM
OutLuDeD
Aug 17, 2003 01:13 PM
Want2race
Jul 13, 2003 11:09 AM
