Greddy Kit from y8 to y7.
someone correct me if im wrong but I believe the IM on both motors are different. I believe the IM on my sisters y8 comes out the side, and on my y7 I believe it came out the top...if memory serves me correct. If thats the case the charge pipes will need to be changed
that is correct, but I would imagine that he could simply get the silicone elbow that you use to hook up a cold air intake to the y7 manifold for like 15 bux.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sky9 »</TD></TR><TR><TD CLASS="quote">soo all parts would fit on and the only difference would be the IM, i just need to mod some pipings?</TD></TR></TABLE>
correct. Actually you'll need a 90 degree hard pipe and 2 straight couplers, that's it. The upper charge pipe will fall about 8" too short from the Y7s vertical TB
And you will likely need to cut a hole in the passenger side fender area for the charge pipe to come up. The Y8 equipped cars have a resonator box, while the Y7 equipped cars don't even have the hole.
