JDM OB1 B18C into, 94 Civic Si
Old Jul 3, 2007 | 03:47 PM
HatchbackSqueegee's Avatar
Default JDM OB1 B18C into, 94 Civic Si
I've been searching and can not find this exact swap info. I know its going to physically drop in and bolt up fine. What I couldn't find out is if I can just use the JDM ECU on my wire harness? If I can are all the wires just PnP? Or do I have to switch pins? What exactly is involved?
Next quest, is the TB the only thing that needs to be changed? if so what exactly do I need to do, get a USDM GSR TB? Or throttle cable? if so what one? And is there any other tricks or guides that might help me with the JDM to USDM swap out?
Again My car is OEM 1994 Civic Si
Thanks for any help.
Old Jul 4, 2007 | 08:58 AM
egsleepercivic's Avatar
ecu will plug in, use the si harness and add wires for knock and IAB(u can find out how to do this by searching), use a 94-01 gsr throttle cable. search for c-speedracing.com they have a walk through on this swap.
gl
what part of orlando?
Old Jul 5, 2007 | 06:03 AM
Default Re: (egsleepercivic)
I've been reading alot about the "adding wires" for the KS and IAB. What I have yet to figure out is when I add wires does that mean I will be running a brand NEW wire from the CPU all the way to the sensor (threw firewall trying to rout it into the correct places)? This seems to be the most confusing part for me.
Old Jul 5, 2007 | 11:17 AM
Lord Helmet's Avatar
Default Re: (HatchbackSqueegee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchbackSqueegee &raquo;</TD></TR><TR><TD CLASS="quote">I've been reading alot about the "adding wires" for the KS and IAB. What I have yet to figure out is when I add wires does that mean I will be running a brand NEW wire from the CPU all the way to the sensor (threw firewall trying to rout it into the correct places)? This seems to be the most confusing part for me.</TD></TR></TABLE>
Yes that's what we mean by adding wires for the ks and iab. If you don't have the wires on hand or don't know how to make the wires and plugs for it, here's a link to buy them: http://stores.ebay.com/HONDAPARTSHERO
Old Jul 5, 2007 | 04:40 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: (Lord Helmet)
if you have any questions feel free to IM or email me
Old Jul 14, 2007 | 11:54 AM
Default Re: (HondaPartsHero)
Ok so you make wire sub harness for the firewall to the engine. But what about from the CPU to the firewall? Does anyone have exact instructions on what wires need to be ran onto what pins? or do you sell kit for that as well? I just want the wires to be VERY clean install.
Old Jul 14, 2007 | 04:04 PM
builthatch's Avatar
MiG-21 superfan
Default Re: JDM OB1 B18C into, 94 Civic Si (HatchbackSqueegee)
http://technet.ff-squad.com/wiring.obd1.htm
http://www.ff-squad.com/tech/w...5.jpg
http://www.ff-squad.com/tech/w...g.jpg
http://www.c-speedracing.com/h...4.php
re: the TB, you don't have to do anything if you are using the dual runner intake mani. if you wanted to use that TB and a single plane intake mani, like a skunk one or something, you'd have to get a 'normal' angle TB rotor from a z6/y8/b16/c5/18b etc
Old Jul 15, 2007 | 04:28 PM
Technical Hero
Default Re: JDM OB1 B18C into, 94 Civic Si (builthatch)
mine go from the sensor to the ECU
Old Jul 16, 2007 | 06:49 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by builthatch &raquo;</TD></TR><TR><TD CLASS="quote">
Really good site for info, I checked out some of the other stuff they had. Just need some kind of picture similar to the link for the KS and IAB and should be set. Thanks for all the links posted they are most helpful. I'll do a full write up on my "common" swap once I'm all done. I'll take lots of pictures and such.
jdmstyleEJ6
15
Feb 4, 2010 09:40 PM
vue-k
Jun 18, 2009 10:40 AM
GSR eg94
Mar 15, 2009 09:05 PM
sibanez
Jun 4, 2007 11:25 AM
GQ Cowboy
May 21, 2006 01:12 AM
