what sensor on the back of the gsr block is this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_dc_199 »</TD></TR><TR><TD CLASS="quote">knock sensor???</TD></TR></TABLE>
I was thinking the same thing. But its not for a sensor. That is where the factory oil cooler connection goes on mine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkertySkerty »</TD></TR><TR><TD CLASS="quote">yeah its a 99 block</TD></TR></TABLE>
so is mine. a b18c1?
If its for an oil cooler like someone up there said, then its supposed to be empty on our cars, they stopped putting oil coolers in after 95. I was pretty sure its supposed to be empty but now im positive if its not tapped.
so whats supposed to go in there because you can see straight into the block looks like maybe a freeze out plug but whatever it is it seems like something like coolant would flow through the hole or something
Knock Sensor should go there.
The Oil Pressure Switch should be located to the left of the Oil Filter Housing if you're facing the back of the block. It should have a single wire that plugs to it with a boot that covers the connector.
The Knock Sensor uses a plug that looks similar to the IACV plug.
Ok Got The Answer To Your Question That Hole In My Block Is Just Blocked Off By A Bolt If You Already Have Your Oil Pressure Sending Unit And Your Knock Sensor You Should Just Plug It Hope This Helped Your Problem. Make Shore The Bolt Is Not Too Long.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkertySkerty »</TD></TR><TR><TD CLASS="quote">so whats supposed to go in there because you can see straight into the block looks like maybe a freeze out plug but whatever it is it seems like something like coolant would flow through the hole or something</TD></TR></TABLE>
For the OE oil cooler. Part#1 threads into that hole. For cars without the oil cooler, just a threaded plug.
krysted9354
Dec 28, 2008 12:43 PM
joedr
Nov 9, 2008 12:11 PM
DevinW
Oct 28, 2002 05:35 PM
