Help wiring a non Vtec with a Vtec
Old Jul 3, 2007 | 08:35 AM
Ckramer's Avatar
Default Help wiring a non Vtec with a Vtec
I have a 94 Civic DX it had a 1.5 non Vtec I put a 1.6 Vtec head on it. I also put in a P28 ECU. It is not wired for Vtec can anyone help me wire it myself. I do not have a harness to work with.
Modified by Ckramer at 10:34 AM 7/3/2007
Old Jul 3, 2007 | 10:25 AM
That Guy 32's Avatar
Default Re: Help wiring a non Vtec with a Vtec (Ckramer)
I'm not sure I understand. You don't have a harness, at all? If that's the case, then just buy a VTEC harness, they go for about 100$ here complete and uncut.
Otherwise, Google "how to wire vtec" and you'll find 943575438753948 pages that completely explain it with pictures.
Old Jul 3, 2007 | 11:49 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Help wiring a non Vtec with a Vtec (That Guy 32)
Old Jul 3, 2007 | 12:17 PM
builthatch's Avatar
MiG-21 superfan
you simply have to worry about a4 and d6. you will also need obd1 pins and a plug that'll work for the vtec solenoid; alot of different sensors use this type of plug (2-wire idle air control valve, knock sensor, etc, etc) so someone should have it laying around for you to use...
Old Jul 3, 2007 | 12:18 PM
Mista Bone's Avatar
D Tranny Guru
4-5 foot of 18 gauge speaker wire and two ECU pins, very easy.
zackmith11
Honda Civic (2001 - 2005)
Aug 13, 2014 07:36 AM
Einhander276
Aug 2, 2011 05:47 PM
sameerb1
Feb 22, 2011 08:33 PM
AIWFCIATR
Jul 23, 2004 12:11 AM
AngelTeg
Aug 24, 2003 07:03 PM
