***searched*** Turbo vaccum line diagram
Old Jul 3, 2007 | 04:43 AM
jdmrex91's Avatar
Default ***searched*** Turbo vaccum line diagram
Like above title says I am completely new to boost and am putting together a FI setup for my dc searched and found no useful info.
Basically if someone had a diagram or had some in depth pics or even could pm me directions I would appreciate it greatly.
Thank You in advance
Old Jul 3, 2007 | 06:33 AM
Topdawgg's Avatar
what do you need to know...
the wastegate needs a good vacuum source, alot of turbos have fittings on the housing itself so it has an accurate source.... but alot of people still run it off the intake manifold..
The BOV also needs a good vacuum source from the intake manifold... A stock intake manifold will only have 1-2 vacuum sources, so you might have to T off an existing line or run a vacuum manifold...
I have a fitting welded to the charge pipes closest to my turbo, and it goes to the wastegate... the BOV goes to the back of the intake manifold...
hope this helps
Old Jul 3, 2007 | 05:42 PM
madteg's Avatar
Default Re: (Topdawgg)
aslo curious if anyone has diagrams and how many vacum fittings should be run on the wastegaste
Old Jul 4, 2007 | 05:22 AM
Topdawgg's Avatar
Default Re: (madteg)
Only need one, and not the top one..
Old Jul 5, 2007 | 12:03 PM
madteg's Avatar
so if I were to make my own boost control with a t valve ball and spring would i put it in between the vaccum source and the wastegate?
Thankx for the great advice josh "jdmrex91" is doing all this for the first time as am I and we appreciate all the advice we get to topdawgg
Old Jul 5, 2007 | 12:15 PM
TunerToys's Avatar
Default Re: ***searched*** Turbo vaccum line diagram (jdmrex91)
Here is the Golden Eagle diagram we offer our customers, when they purchase a vacuum manifold. It should help with a couple of your connections. It's in PDF format.
http://www.goldeneaglemfg.com/...C.pdf
Thanks from Craig
Old Jul 5, 2007 | 08:25 PM
jdmrex91's Avatar
Default Re: ***searched*** Turbo vaccum line diagram (TunerToys)
Hey thankx craig!!!! My first experience with boost is turning into something great not a pain in the *** I love all the help I am gettin from my fellow HT members Thank You all
Old Jul 5, 2007 | 10:27 PM
HiProfile's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmrex91 &raquo;</TD></TR><TR><TD CLASS="quote">Hey thankx craig!!!! My first experience with boost is turning into something great not a pain in the *** I love all the help I am gettin from my fellow HT members Thank You all </TD></TR></TABLE>
lol, then whatever you do, DO NOT go to homemadeturbo.com.
Go read this: http://www.beesandgoats.com/bo....html
That should give you a good idea on vac routing, along with everything else.
Old Jul 8, 2007 | 06:36 PM
jdmrex91's Avatar
Default Re: ***searched*** Turbo vaccum line diagram (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">
That should give you a good idea on vac routing, along with everything else.</TD></TR></TABLE>
WOW!!!! That is an awesome write up and I would suggest it to anyone thankx a lot for that.
for the all the help from HT's boost gurus!!!!
Old Jul 10, 2007 | 07:06 PM
NBenn02's Avatar
[QUOTE=HiProfile]
QUOTE]
Haha.Whats wrong with HMT?
Old Jul 16, 2007 | 04:58 PM
madteg's Avatar
Default Re: ***searched*** Turbo vaccum line diagram (NBenn02)
everything...................................
Old Jul 20, 2008 | 03:32 PM
91_civic_si's Avatar
Default Re: ***searched*** Turbo vaccum line diagram (madteg)
great info just reading this form but thanks good reading
EastCoastRust
Aug 11, 2014 11:06 AM
19_HaTcH_92
Feb 20, 2010 03:24 PM
xcellorator
May 8, 2006 07:05 PM
1.8
Dec 26, 2004 09:38 PM
quick gixxer
Jul 16, 2004 08:05 AM
