T3 manifold to T4?
Old Jul 3, 2007 | 12:41 AM
blackpearlcivic's Avatar
Default T3 manifold to T4?
Hey guys i wanna buy a new turbo T4 butt my mani is a RLD Ramhorn T3.Butt is it easy to cut T3 flange and weld a T4 fkange on it?Because the welding is not to hard for me butt i dont now how muchs the different is between these flanges?
I hope some one can show me a pic off it.
Old Jul 3, 2007 | 03:27 AM
DaveF's Avatar
Default Re: T3 manifold to T4? (blackpearlcivic)
its a bit of differance, to get the collector to match up you will have to cut a good 1/2inch off of the bottom of it. (not including the t3 flange)
send it back to Ron, im sure he will have no problem doing the flange swap for you.
Old Jul 3, 2007 | 04:37 AM
Default Re: T3 manifold to T4? (dturbocivic)
I live in Europe so than i have to send it back to the US and that is very expensive.Butt if i can modifeid it than i do that.
Thanks for the answer dturbocivic .
Old Jul 3, 2007 | 04:42 AM
DaveF's Avatar
oh, sorry, i didnt realise you were all the way over there ! but goodluck with it
Old Jul 3, 2007 | 04:53 AM
No problem man butt thanks .
Old Jul 3, 2007 | 05:31 AM
DfwBB6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackpearlcivic &raquo;</TD></TR><TR><TD CLASS="quote">No problem man butt thanks .</TD></TR></TABLE>
I just got a SFP manifold that was a t3 converted to a t4. So yeah if you have a good welder it can be done
Old Jul 3, 2007 | 08:19 AM
B18C1CYA's Avatar
what , I would do is get a dual drilled inlet flange wich has bolt patterns for T3 and T4 exhaust housings ,http://www.bmcrace.com/product_info....roducts_id=159 , and then drill the threads out of the flange on the manifold and bolt the dual drilled flange up to that , do some quick port matching with a die grinder , then attach the T4 turbo ith studs and nuts , easyest and fastest way to do it with out making undoable changes ,
Old Jul 3, 2007 | 08:23 AM
Default Re: T3 manifold to T4? (B18C1CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">what , I would do is get a dual drilled inlet flange wich has bolt patterns for T3 and T4 exhaust housings ,http://www.bmcrace.com/product_info....roducts_id=159 , and then drill the threads out of the flange on the manifold and bolt the dual drilled flange up to that , do some quick port matching with a die grinder , then attach the T4 turbo ith studs and nuts , easyest and fastest way to do it with out making undoable changes ,</TD></TR></TABLE>
Butt than i have another problem because a T4 turbo is huge so the turbo gets a lot lower than it already is.
Old Jul 3, 2007 | 08:30 AM
B18C1CYA's Avatar
it is only about 1/2" more
Old Jul 3, 2007 | 10:46 AM
Ok than i do that .
Old Jul 5, 2007 | 04:04 AM
93supercoupe's Avatar
u will be port matching for a while, but its worth it.
Maker it baby smooth and the exhaust gasses wont know any better
JDMgsrTeg08
Welding / Fabrication
May 14, 2010 09:01 PM
shabam
Feb 27, 2010 10:39 PM
BOOSTEDk24a4
Jun 25, 2007 09:51 AM
saywhat
May 23, 2006 12:05 PM
BlueLude94
Oct 31, 2005 07:39 AM
