Weird headlight problem - diagram included
Old Jul 2, 2007 | 10:43 PM
Lou_EM1's Avatar
Default Weird headlight problem - diagram included
Alright well, my car came with some ricer halos and after taking them off I noticed that my pass. headlamp would not work. I got a used harness and now I have a new problem which might be the wiring or perhaps something else.
The problem is that when my normal lights are on I have a dim highbeam dash light and my passanger's side lamp is on very low and my driver's is fine. When I click on my highbeams both sides work evenly, and the highbeam light in my dash is on as it is supposed to be.
I am thinking it may be my wiring.. I am not sure since they came with ricer lights that had wires going every which way. But, to illustrate there are 4 wires coming from my light harness: 2 black 1 red 1 blue and I connected them to the headlamp prongs. The pic below is how I wired them if you were to see them looking down from the front (the yellow ball at the bottom is supposed to be a bulb). Both sides are wired the same.
NO BLOWN FUSES NEW BULBS
What is the other black wire (currently not connected to anything) also does it matter which wire goes to which prong?
Thanks.
Old Jul 3, 2007 | 08:04 AM
Lou_EM1's Avatar
Default Re: Weird headlight problem - diagram included (Lou_EM1)
Old Jul 3, 2007 | 08:17 AM
98greensi's Avatar
check the 2 black wires they should be your grounds, one is probily for high and the other should be for low beam check and make sure both have a good ground connection nice and shinney metal where the goto the body
Old Jul 3, 2007 | 08:20 AM
Lou_EM1's Avatar
Default Re: Weird headlight problem - diagram included (98greensi)
I don't know what you're saying.
Both should go to the chasis? Both what? There are 4 black wires, 2 on each side and 1 on each side is connected to the bulbs, the other two are currently not connected - should those two be grounded to the chasis or are you saying the two black wires on each relay be grounded to the chasis?
Old Jul 3, 2007 | 01:44 PM
Lou_EM1's Avatar
Up.
Old Jul 4, 2007 | 02:31 PM
Lou_EM1's Avatar
Old Jul 5, 2007 | 03:08 PM
Lou_EM1's Avatar
tylerstephen11
Sep 7, 2018 03:37 PM
SinsEvil666
Mar 17, 2010 09:04 PM
5poonhatch
May 26, 2005 10:33 PM
RedHackBatch
Jul 6, 2004 09:39 PM
toEknEEg
Oct 6, 2003 04:04 PM
