honda crx ecu blinks 9 times
Old Jul 2, 2007 | 10:40 PM
supaf1y's Avatar
Default honda crx ecu blinks 9 times
i was starting like how u race and then my engine light came on and soo i turned it off and turned it back on but it was idleing soo i waited a while andit turned on then the engine light was still on i looked at the ecu it was blinking 9 times and i searhed it up online and its the number 1 cylener thing but what is that whats wrong with my car
Old Jul 2, 2007 | 11:30 PM
crxforum's Avatar
Default Re: honda crx ecu blinks 9 times (supaf1y)
Was it 9 quick flashes or 1 long flash and 8 quick ones?
To read an ECU that is OBD0 like our CRXs this is how it works.
A quick flash = 1
A long flash = 10
If there is a space in the middle that doesnt flash that means its either repeating the code over or that it is telling you a seperate code later on.
So if a quick flash = . and a long flash = / this is how you read the code
/ . . . . . = 15
/ . . ----. . . . . ----/ . . . . = 12 for first code, 5 for second code and 14 for third code.
When you have the code figured out then open up your helms manual and follow the trouble shooting guide to fix the codes.
Also another trick to try is to reset the ECU, there are a few ways to go about this. You can either disconnect your battery for an hour or so and let the electricity ground out to nothing in the car. You can pull your hazard fuse for 20min or so and do it that way, or you can unplug the ECU for about 15min and then plug it back in. Then read the code again. Sometimes resetting an ECU will solve the problem without having to repair anything due to the ECU getting a false reading or just bugging a bit which they sometimes do.
CRX Forum
Old Jul 2, 2007 | 11:38 PM
ef92b's Avatar
Default Re: honda crx ecu blinks 9 times (crxforum)
^^ what he said
Old Jul 3, 2007 | 01:34 AM
supaf1y's Avatar
Default Re: honda crx ecu blinks 9 times (ef92b)
i noe how that works cuz it blinks 1 times for my o2 sensor i noe thats and then the 9 times and then 17 for the speed sensor but my engine light dont come on untell now cuz the 9 blinks i need to noe what i need to replace cuz my o2 it comes on but not all the time cuz its old now the engine light steys on
Old Jul 3, 2007 | 08:38 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxforum &raquo;</TD></TR><TR><TD CLASS="quote">Was it 9 quick flashes or 1 long flash and 8 quick ones?
A quick flash = 1
A long flash = 10
/ . . . . . = 15
CRX Forum</TD></TR></TABLE>not true for 88-91 CRX/Civic (unless you have a PR3 or PW0 B16 VTEC ECU or a PR4 ECU from 90-91 Integra) - all of the stock USDM 88-91 CRX/Civic ECUs, 88-89 Integra PG7 and JDM DOHC ZC PM7 only have short flashes - if it flashes 17 times, it is code 17 - there are no long and short flashes
Old Jul 3, 2007 | 10:26 AM
CRXDaddy78155's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supaf1y &raquo;</TD></TR><TR><TD CLASS="quote">i noe how that works cuz it blinks 1 times for my o2 sensor i noe thats and then the 9 times and then 17 for the speed sensor but my engine light dont come on untell now cuz the 9 blinks i need to noe what i need to replace cuz my o2 it comes on but not all the time cuz its old now the engine light steys on</TD></TR></TABLE>
Spelling 101:
noe=KNOW
untell=UNTIL
cuz=BECAUSE
steys=STAYS
Reading your english gives me a headache.
Old Jul 3, 2007 | 10:53 AM
503_EF9's Avatar
Default Re: honda crx ecu blinks 9 times (CRXDaddy78155)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXDaddy78155 &raquo;</TD></TR><TR><TD CLASS="quote">
Spelling 101:
noe=KNOW
untell=UNTIL
cuz=BECAUSE
steys=STAYS
Reading your english gives me a headache. </TD></TR></TABLE>
thankyou i hate that. people are even helping you and your still make it hardly legible. take the time to reread your question or at least be careful at your typing. if your that lazy google toolbar makes a good spellcheck. im not trying to be an *** its for your own good.
Old Jul 3, 2007 | 05:47 PM
supaf1y's Avatar
but could the 9 blinks be from my distributor do i have to replace it
Old Jul 3, 2007 | 06:08 PM
89s1's Avatar
in the FAQ above there is Code reading & Troubleshooting section... Ive been there many times, as i tend to research my problem myself before asking about it (it gets kinda tiring when your one of the helpful ones that tries to answer questions)
the sensor that trips code 9 usually lives in the dizzy, so to answer ^your question^ its possible yes... however i would do a bit of research before i opened my wallet at any auto parts supplier.
Maybe try a dizzy off a working coworkers car, or a friendly person around the neiborhood
Modified by 89s1 at 8:26 PM 7/3/2007
duh blacksheep
Dec 13, 2004 07:54 AM
carnifex
Oct 1, 2004 10:28 AM
nomavtec
Jul 18, 2003 01:14 PM
brega3
Jun 30, 2003 03:43 PM
