What sould I do to supe up my d15b7?
ummm throw nos for the cheapest hp...
throw on a HMT http://www.homemadeturbo.com for 600=900
or mini me swap...(do a search)
https://honda-tech.com/zerothread?id=554053
My friend is in the process of doing a mini-me with a D15b Vtec head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cool_junk »</TD></TR><TR><TD CLASS="quote">"d15b head" sorry</TD></TR></TABLE>
We have the edit button for a reason, no need to double post.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cool_junk »</TD></TR><TR><TD CLASS="quote"> How much of a shot of nos would be safe on a stock engine?
Drew</TD></TR></TABLE>
depends on if its tuned or not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cool_junk »</TD></TR><TR><TD CLASS="quote">What do you mean by tuned?
oh dear.
oh dear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Lobster »</TD></TR><TR><TD CLASS="quote">
oh dear.</TD></TR></TABLE>
x2
x2
You can't just add nitrous. You will blow up your motor that way. Take it to a shop, they will install the nitrous, and tune your car. That means getting a new fuel management system (either a chipped ECU, or some other fancy engine management system.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cool_junk »</TD></TR><TR><TD CLASS="quote">What sould I do to supe up my d15b7 to add HP for cheap. Is there some kind of head swap for it?
And this is why the world hates Hondas.
What happened, got owned by a stock neon and realized your stock DX which you thought ran 13's is slower than ****?
Search, this has been covered too many times.
What I would do:
- Mini-me - (D15B7/VTEC - Put a D16Z6 head on it - write-up/how-to = here.
- Slap an EX transmission on it - 2nd, 3rd, and the final drive are all shorter making a noticeable increase of power.
Do those two things with a short ram intake (cheap ****, no need to spend 250 bux on it, just get a good filter w/ a short cheap **** pipe), header (again, you don't need a 400 dollar header, any 60 dollar header would do for increased flow on a low power D), and exhaust (get a cheap catback, again, you don't need a 600 dollar exhaust).
That'll make a dramatic increase of power from the way the stock B7 is. It'll just about level you with Z6's - probably put you around 130hp at the flywheel if you do your research right.
What I would do:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">
What I would do:
That'll make a dramatic increase of power from the way the stock B7 is. It'll just about level you with Z6's - probably put you around 130hp at the flywheel if you do your research right.</TD></TR></TABLE>
Damn... that's sad.. all that for 130 ish.. Now I see why everyone says swap..
What I would do:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">LOL, mini-me is SOOO not worth it.
Ask the guy who WROTE the mini-me write-up.</TD></TR></TABLE>
If you can't afford a swap and you have a B7 - mini-me and Si/Ex trans is DEFINITELY the way to go and COMPLETELY worth it.
It's like bolting on 25hp.
Then getting shorter gears with the 4.25 FD instead of the 4.0 or whatever it is - along with the shorter 2nd and 3rd.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECth1s »</TD></TR><TR><TD CLASS="quote">turbo =
FTW!</TD></TR></TABLE>
Fixed,
Mini-me or not, you can make the same numbers.
FTW!</TD></TR></TABLE>Fixed,
Dude, don't invest too much in that little motor, even if it is to replace like half of it. I say if you're going to upgrade a D, go all or nothing; A full engine swap or no swap.
IMO, just go for a cheap-*** turbo setup with a good tune, maybe even a transmission swap, and run it. A turbo will get you the gains that you want (I/H/E will not, trust me), and can be pretty cost-effective. Just do that, and run it until you get enough money for a more powerful engine, or blow the **** up, and leave it until you can afford to do anything to it that's worthwhile.
PNPFLIPPED
10
Dec 16, 2005 07:46 AM
