***Tein S Tech and H Tech Lowering Springs***
<u>Tein S Tech Lowering Springs</u>
Tein is a well-known name when it comes to spring and coilover damper kit. Tein products are made in Japan with high-grade material for performance and quality.
Tein S Tech lowering spring provides approximately between 1.3 to 2.5 inch drop for a more aggressive appearance. Check the detail specifications of each Tein spring set for your car for the exact height drop measurement. Most Tein S Tech spring sets feature rubber spring protector tube to dampen noise level. Tein S Tech springs are made with special high quality powder coating and painting treatment to prevent rusting.
***Click below for pricing and spring specs Tein S Tech Lowering Springs***
http://www.raceinspired.com/sh...rby=1
Applications for Tein S Tech Lowering Springs:
<ul>[*]Acura CL 1996-00 4Cyl 2DR[*]Acura CL 2001-03 Coupe Incl. Type S[*]Acura Integra 1990-93[*]Acura Integra 1994-01 Exc. Type R[*]Acura Integra 1999-01 Type R[*]Acura NSX 1991-02 NA1[*]Acura NSX 1997-06 NA2[*]Acura RSX 2002-04[*]Acura RSX 2005-06[*]Acura TL 1999-03 4DR Incl. Type S[*]Acura TL 2004-UP 4DR V6[*]Acura TSX 2004-UP[*]Honda Accord 1990-93 4Cyl[*]Honda Accord 1994-97 4Cyl[*]Honda Accord 1998-02 4Cyl[*]Honda Accord 1998-02 V6[*]Honda Accord 2003-UP 4Cyl[*]Honda Accord 2003-UP V6[*]Honda Civic 1988-91[*]Honda Civic 1992-95[*]Honda Civic 1996-00[*]Honda Civic 2001-05 2DR[*]Honda Civic HB EP3 2003-05[*]Honda Civic 2006-UP 2DR Exc. SI[*]Honda Civic SI 2006-UP[*]Honda CRX 1988-91[*]Honda Del Sol 1993-97[*]Honda Element 2003-06 2WD[*]Honda Element 2003-06 AWD[*]Honda FIT 2007-UP[*]Honda Prelude 1992-96[*]Honda Prelude 1997-02[*]Honda S2000 2000-UP[/list]
All Tein S Tech Lowering Springs feature:
<ul>[*]Cold-coiling to create the spring [*]Low temperature tempering treatment to eliminate residual stress [*]End-face grinding according to the form of each car application [*]Double shot peening to the spring surface to increase spring life [*]Setting at elevated temperature to minimize loss of spring load [*]Tein S Tech spring comes with rubber spring protector tube to reduce noise[*]Tein S Tech spring made with high quality powder coating and painting treatment to prevent rusting [*]Tein S Tech spring made in Japan [*]Tein 1 year limited warranty[/list]
<u>Tein H Tech Lowering Springs</u>
Tein H Tech lowering spring provides approximately between 1.0 to 1.9 inch drop to achieve a balance between aggressive styling and comfortable ride experience. Check the detail specifications of each Tein H Tech spring set for your car for the exact height drop measurement. Most Tein H Tech spring sets feature rubber spring protector tube to dampen noise level. Tein H Tech springs are first coated with zinc phosphate, a rust-proof material. The H Tech springs are then finished with a long-lasting gold powder paint. In addition, each Tein H Tech spring is made using a new material called Vanadium (SAE9254V), a strong, lightweight material that retain more spring stroke for optimal quality.
***Click below for pricing and spring specs for Tein H Tech Lowering Springs***
http://www.raceinspired.com/sh...ID=44
Applications for Tein H Tech Lowering Springs:
<ul>[*]Acura CL 2001-03 Coupe Incl. Type S[*]Acura Integra 1990-93[*]Acura Integra 1994-01 Exc. Type R[*]Acura Integra 1997-01 Type R[*]Acura RSX 2002-04[*]Acura RSX 2005-06[*]Acura TL 1999-03 4DR Incl. Type S[*]Acura TL 2004-UP 4DR V6[*]Acura TSX 2004-UP[*]Honda Accord 1990-93 4Cyl[*]Honda Accord 1994-97 4Cyl[*]Honda Accord 1998-02 4Cyl[*]Honda Accord 1998-02 V6[*]Honda Accord 2003-UP 4Cyl[*]Honda Accord 2003-UP V6[*]Honda Civic 1992-95[*]Honda Civic 1996-00[*]Honda Civic 2001-05 2DR[*]Honda Civic HB EP3 2003-05[*]Honda Civic 2006-UP 2DR Exc. SI[*]Honda Civic SI 2006-UP[*]Honda Del Sol 1993-97[*]Honda Prelude 1992-96[*]Honda Prelude 1997-02[*]Honda S2000 2000-UP[/list]
All Tein H Tech Lowering Springs feature:
<ul>[*]Cold-coiling to create the spring [*]Low temperature tempering treatment to eliminate residual stress [*]End-face grinding according to the form of each car application [*]Double shot peening to the spring surface to increase spring life [*]Setting at elevated temperature to minimize loss of spring load [*]Tein H Tech spring made from new strong, lightweight Vanadium material for optimal quality[*]Tein H Tech spring combines a balance between styling and comfortable ride[*]Tein H Tech spring comes with rubber spring protector tube to reduce noise[*]Tein H Tech spring made with high quality powder coating and painting treatment to prevent rusting [*]Tein H Tech spring made in Japan [*]Tein 1 year limited warranty[/list]
***Please PM me with your cars make, model and year and type of suspension springs you are interested in. Shipping varies depending on location. So please include your shipping zip code for shipping quote as well. Please enjoy and feel free to ask any questions.***
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaceInspired »</TD></TR><TR><TD CLASS="quote">ttt</TD></TR></TABLE>
young noob #2
Suspension & Brakes
10
Jul 29, 2008 11:57 AM
CheezeFrog
Apr 21, 2002 12:26 AM
