Grey Welds with SS and only 40 amps on the tig
Old Jul 2, 2007 | 09:37 AM
JDMCRX's Avatar
Default Grey Welds with SS and only 40 amps on the tig
I dunno why but my welds are coming out grey which i thought was too hot so i turned it down to 40amp?? Any one.
Welding 1/16" exhaust piping SS with 3/32 Tungstien. and 40amps
Old Jul 2, 2007 | 09:46 AM
david@didrace.com's Avatar
Default Re: Grey Welds with SS and only 40 amps on the tig (JDMCRX)
I usually set the machine to 27 amps and get just about full pedal. So I'd say around 23-25 amps.
Old Jul 2, 2007 | 10:04 AM
JDMCRX's Avatar
Default Re: Grey Welds with SS and only 40 amps on the tig (david@didrace.com)
Ok im gonna try that and also gas is at 10cfm
Old Jul 2, 2007 | 10:24 AM
tony1's Avatar
Yeah, 40 amps is too much for 16ga butt welds.
Old Jul 2, 2007 | 10:35 AM
shortyz21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX &raquo;</TD></TR><TR><TD CLASS="quote">Ok im gonna try that and also gas is at 10cfm</TD></TR></TABLE>
crank that **** up to 30..
to little gas will hurt your welds, to much wont.
p.s. dont keep SS hot for to long, if u lift your hood and your piece is red hot, chances are its gonna rust on the weld. also make sure u keep your postflow on the piece after u stopped the arc.
Old Jul 2, 2007 | 10:47 AM
JDMCRX's Avatar
Perfect man thanks put it at 29 and the welds are coming out nice
Old Jul 2, 2007 | 10:48 AM
JDMCRX's Avatar
Ok cool and turned the gas to 18
Old Jul 2, 2007 | 11:30 AM
Bailhatch's Avatar
do you not have a foot pedal?
Old Jul 2, 2007 | 11:35 AM
JDMCRX's Avatar
Default Re: Grey Welds with SS and only 40 amps on the tig (Bailhatch)
Yeap but like he posted its easy to keep it at certin amps. I just did most of the exhaust and the welds are alotttt better
Old Jul 2, 2007 | 01:00 PM
chadr's Avatar
i've been practicing at about 45 amps on mild steel 1/16 tubing so I guess I'll try to lower that to 25-30 to see the results. The tig calculator on the miller site recommends 50-80 amps so why the huge difference?
Old Jul 2, 2007 | 03:16 PM
danielm3's Avatar
Default Re: Grey Welds with SS and only 40 amps on the tig (chadr)
When I 1st starte welding, I used to weld SS at like 70+ amps haha and I never understood why i would get crazy holes everywhere.
Old Jul 2, 2007 | 03:32 PM
9bells's Avatar
OG Fabricator
Mild steel requires a little more heat to weld in relation to thickness.
Also, the effects of too much heat are minor on mild steel.
It has to do with thermal conductivity, stainless has less.
This means the heat does not spread through the work as fast, enabling the use of less heat to maintain the puddle.
It's also ther reason why stainless distorts more.
Old Jul 2, 2007 | 06:46 PM
JDMCRX's Avatar
Default Re: Grey Welds with SS and only 40 amps on the tig (9bells)
Well i did the 29 amps and floor it and wow my beads are coming out very nice. here is a pic not very clear but alot better
Old Jul 2, 2007 | 07:22 PM
EdsGTI's Avatar
23 is pin tiny welds for me, 26 is what ive been using, .030 308l filler.
if im above 30 it gets hot or undercut. Ive been having success with ~55 amps from flanges - .065 as well.
Old Jul 5, 2007 | 10:16 PM
berts95ej's Avatar
* B A N N E D *
Default Re: (EdsGTI)
http://img528.imageshack.us/my...7.jpg
not sure if this link will work or not
Old Jul 6, 2007 | 09:21 AM
Sims's Avatar
Default Re: Grey Welds with SS and only 40 amps on the tig (shortyz21)
too much gas with a gas lens will actually swirl oxygen from the atmosphere and hurt the weld quality...
Old Jul 6, 2007 | 07:26 PM
*Boostwerks*'s Avatar
Default Re: Grey Welds with SS and only 40 amps on the tig (Sims)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sims &raquo;</TD></TR><TR><TD CLASS="quote">too much gas with a gas lens will actually swirl oxygen from the atmosphere and hurt the weld quality...
Do you have a gas lense? Too little gas coverage can produce the same results as much heat.
Old Jul 7, 2007 | 05:36 AM
Agtronic's Avatar
Default Re: Grey Welds with SS and only 40 amps on the tig (Boostwerks.com)
If you are using a standard-style cup on your torch, too much gas is just as bad as too little. You have to find that sweet spot, which varies with cup size. I use between 10 and 25 cfh depending on cup size. More than that, and the turbulence starts to mix ambient air into the gas as it leaves the cup.
If you are using a gas lens, you can crank it to 30 if you want, and it will cover you nice and good.
If you're welding stainless, I would definitely recommend a gas lens setup. Works great.
shortyz21
Welding / Fabrication
25
Jan 7, 2006 04:11 PM
all_conference
67
Jul 28, 2005 02:05 PM
Want2race
Jun 17, 2005 06:39 AM
thatonejewishguy
May 28, 2005 08:41 PM
xunkn0vvnx
Mar 30, 2005 05:33 PM
