To all the Turbo Type R's out there. Please read.
Old Jun 7, 2002 | 07:21 AM
RATEDR's Avatar
Default To all the Turbo Type R's out there. Please read.
If you could, please follow this link to my post in the forced induction forum and add any advice you can. Thanks in advance.
https://honda-tech.com/zerothread?id=203073
Old Jun 7, 2002 | 08:25 AM
RATEDR's Avatar
Default Re: To all the Turbo Type R's out there. Please read. (RATEDR)
ttt
Old Jun 7, 2002 | 08:28 AM
poison's Avatar
i think that thread pretty much has you covered. that's really all you need, other than your built block
good plan of not going anymore than 6 psi......and i know you're gonna have that itch to raise it to 7, or maybe 8 a couple times, but i wouldn't if i were you
Old Jun 7, 2002 | 08:39 AM
DC2R714's Avatar
Default Re: To all the Turbo Type R's out there. Please read. (poison)
Hardest thing when having turbo,Not wanting to inch the boost up. But with the high compression I wouldn't risk it.
Old Jun 7, 2002 | 09:04 AM
RATEDR's Avatar
Default Re: To all the Turbo Type R's out there. Please read. (DC2R714)
Yeah, dont worry Im tuning it for 6psi and not touching it again...I dont care what happens.
I have my golden eagle sleeved block getting built later this month so I'll be able to handle more boost very soon...
thanks guys.
Old Jun 7, 2002 | 09:36 AM
adam's Avatar
you forgot injectors, i'd get at least 440cc. depends on how much boost you plan to run.
[Modified by adam, 1:37 PM 6/7/2002]
Old Jun 7, 2002 | 11:23 AM
B18CXr's Avatar
Default Re: To all the Turbo Type R's out there. Please read. (adam)
10 lbs all day on that setup, just don't let her knock!!
KEEP THE RETURN LINE TO THE FMU TIGHT!!!!!!!!
Old Jun 7, 2002 | 12:09 PM
RATEDR's Avatar
Will do Jack..thanks.
Adam i'll be running stock injectors with a high pressure in-tank Walbro fuel pump. I plan to get RC 550's when I get the hondata.
Old Jun 7, 2002 | 12:24 PM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Instead of a Honddata you might want to go with an AEM ECU. It's got built in boost control so that'll save you a few hundred right there, plus it's got built in timing retard based on both knock and boost, you'll need a J&S or a BTM if you want that with a Hondata setup.
Old Jun 7, 2002 | 12:26 PM
Black R's Avatar
25 Year Member
Default Re: To all the Turbo Type R's out there. Please read. (newt2)
.....see the list - j&s is included.
hondata
Old Jun 7, 2002 | 01:00 PM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Default Re: To all the Turbo Type R's out there. Please read. (Black R)
It's included in the price or are you buying it seperate?
If you're getting it as part of a package, cool. If not it seems to make more sense to not have any black boxes anywhere in the car.
Black Boxes -
Standalones that do everything -
Old Jun 7, 2002 | 01:02 PM
sgT's Avatar
sgT
Black boxes? what the hell.
Old Jun 7, 2002 | 01:08 PM
RATEDR's Avatar
Everything listed in my set up is coming as a package deal. I just added one other thing that its coming with...the missing link map bypass sensor.
But yeah, its all together as a package deal. Im buying the egt gauge, injectors, in-tank fuel pump and Hondata seperately.
Old Jun 10, 2002 | 06:08 AM
RATEDR's Avatar
Another question?: Would a Power Enterprise timing belt be a good thing to get as well?
Old Jun 10, 2002 | 07:30 AM
sgT's Avatar
sgT
not really necessary for FI app. nnice to have but not necessary
Old Jun 10, 2002 | 08:30 AM
RATEDR's Avatar
Default Re: To all the Turbo Type R's out there. Please read. (sgT)
cool, thanks.
Now to find a place that sells Walbro fuel pumps.
Old Jun 10, 2002 | 08:35 AM
sgT's Avatar
sgT
summit
Old Jun 10, 2002 | 09:02 AM
RATEDR's Avatar
Called Summit, they say they dont carry Walbro. I asked if they knew of anyone who does and they said they dont know any mail order companies that do.
Old Jun 10, 2002 | 09:11 AM
sgT's Avatar
sgT
try jegs then lol
FYI, holley and BBK are rebadged walbros
Old Jun 10, 2002 | 09:22 AM
adam's Avatar
yah i got my pump there. walbro 255 rebadged as BBK (the civic one, it plugs right in)
Old Jun 10, 2002 | 09:31 AM
RATEDR's Avatar
okie...yeah i saw jc whitney sells BBK...now I know that they will work...time to call!
thanks again
gator1
Jun 4, 2009 10:55 AM
1BADEGDC2
Sep 9, 2007 08:19 AM
si90rex
Jun 7, 2006 08:17 AM
danny98r
Sep 12, 2005 08:09 AM
SwiftTypeR
Jan 30, 2002 05:44 AM
