jdm usdm upgradeing?
Old Jul 2, 2007 | 06:46 AM
91efhbsi's Avatar
Default jdm usdm upgradeing?
I have finally decided on what motor go wit in my 91 si i have chosen b18 type r , my question is will parts from such companies as skunk2 and such work on a jdm motor or is there a difference in the usdm and jdm that would prevent the fitting of such parts let me know , im still new to civics i tyed surching and came up with off the wall **** so lil help plz i would hate pay all that money then not able get parts ,thanks jim
Old Jul 2, 2007 | 07:01 AM
Phil M's Avatar
Default Re: jdm usdm upgradeing? (91efhbsi)
The JDM and USDM engine are all the same in relation to size and bolt location. You can use JDM cams in USDM engines and visa versa. So, you can use skunk cams in both engines.
Modified by Phil M at 8:32 AM 7/2/2007
Old Jul 2, 2007 | 07:17 AM
91efhbsi's Avatar
Default Re: jdm usdm upgradeing? (Phil M)
Thank you , and in the future don't criticize some one when you don't know them i am blind I'm my left eye i have to wear thick lens glasses and i suffer from the disability called dyslexia
Old Jul 2, 2007 | 07:31 AM
Phil M's Avatar
If this is true, then I am truly sorry. However, it is all too common for people to type this way and they are perfectly healthy.
Old Jul 2, 2007 | 09:58 AM
91efhbsi's Avatar
This is true in my case
Old Jul 2, 2007 | 10:46 AM
b19coupe's Avatar
USDM and JDM engines are basically interchangeable. I am dyslexic too, thank God for spell check!
Old Jul 2, 2007 | 08:48 PM
91efhbsi's Avatar
Default Re: (b19coupe)
Makes life a lil bit easier
VTECcnIT
Feb 8, 2006 01:50 PM
Integra4lyfe
Nov 10, 2003 09:06 AM
iwhichisme
27
Aug 1, 2002 12:51 PM
