oil pan gasket
Old Jul 2, 2007 | 12:18 AM
lazyxmofo's Avatar
Default oil pan gasket
does anyone know how much it costs to change the oil pan gasket for a DA at the shop?...
Old Jul 2, 2007 | 12:58 AM
__oversea's Avatar
Default Re: oil pan gasket (lazyxmofo)
why dont you do it yourself? only few tools needed, and time.
all you have to do is remove oil and 7-8 bolts.
Old Jul 2, 2007 | 01:03 AM
lazyxmofo's Avatar
Default Re: oil pan gasket (KaNgPrEzA)
oh really?....thought it was hard...someone told me that theres a lot of bolts...i never changed one before.....just wondering if anyone had it done at the shop n how much was it
Old Aug 15, 2007 | 11:50 PM
Tank INC.'s Avatar
Default Re: oil pan gasket (Sunrise Dr)
im doing a oil pan gasket tomorrow .does any one got any healpfull tips?
Old Aug 16, 2007 | 12:32 AM
1.8L_allmotormilitia's Avatar
drain out your oil un bolt it. take old gasket off or scrap it off if its fuked. put new one on and bolt it on. replace oil.
Old Aug 16, 2007 | 09:21 AM
g0tgot's Avatar
"GOLF CLAP"
Old Aug 16, 2007 | 09:29 AM
dizzzane's Avatar
Default Re: (g0tgot)
It really is that simple. Drain the oil. Unbolt the drain plug (17mm). Loosen the oil pan bolts (10mm I believe) and scrape off the residue the old gasket left behind. Put the new gasket into the oil pan seal and bolt the oil pan bolts back. Don't forget the drain plug and 4.2ish fresh quarts of oil .
Old Aug 16, 2007 | 10:53 AM
4nmusle 2.1's Avatar
its alot more then 7to8 boplts on the oil pan and the easy way to do it for a *** for the frist time would to be take down the headers so he has a clear veiw of whats going on ....... other then that everything sounds right
Old Aug 16, 2007 | 09:47 PM
Tank INC.'s Avatar
Default Re: oil pan gasket (4nmusle 2.1)
thanks for the help!
Old Aug 16, 2007 | 09:59 PM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Re: oil pan gasket (Tank INC.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4nmusle 2.1 &raquo;</TD></TR><TR><TD CLASS="quote">its alot more then 7to8 boplts on the oil pan and the easy way to do it for a *** for the frist time would to be take down the headers so he has a clear veiw of whats going on ....... other then that everything sounds right </TD></TR></TABLE>
Um, you mean header, and why, thats more work, when he can just jack the car up...
Mattyg2
Aug 28, 2004 04:50 PM
MR. ARIZONA
Sep 3, 2003 05:04 PM
d0nkeyxPunch
May 10, 2002 04:01 AM
imported204
Apr 22, 2002 02:33 PM
