help with installing alarm
i am intsalling a python 460hp alarm in my 96 civic ex coupe, i have everything hooked up except the parking lights wire. im trying to find the wire i have to hook up the alarms wire to. if anyone knows wich wire it is and where i can find it please let me know. ive been searching for the last 2 hours on the web and havent found anything so i hope someone on here can help me out.
Which wire are you talking about? The audio/security section would be the right place to post this. There are many knowledgeable people in there that could help you. But meanwhile you might want to check out http://www.the12volt.com ...They have wiring charts that you might find useful.
i know theyre parts are shitty but bulldogsecurity.com has wiring info on your car. that what i use when im installing an alarm in someones car
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Its the red/black wire. You should allways test your wire with a dvm. Never hook up a wire just because a sheet told you it is it. You can catch that wire behind the radio, cluster,kick pannel or third pin on the fuse pannel. I would not use the fuse pannel because a theif would just follow the wire back to the brain.
EnSAn
24
Aug 10, 2006 08:36 AM
cxSHOE
Audio / Security / Video
28
Mar 15, 2004 05:24 AM
