245-50-16
i am ordering new tires for the rear. i have searched numerous times and seen that if i am not getting the stock so-2s i should get a 245 size tire.. only problem is that the tires i want do not come in size 245-45, like suggested in many threads... will a 245-50 fit in the rearend without a lot of change in the speedo calibration and fitment?
TIA
TIA
I'm running 245/50-16 in the rear with no fitment issues. The speedo is going to read a little high, but it's not the end of the world if you keep that in mind on the interstate.
Cool Cool Island Breezes. BOY-EE
speedo will read slow. The wheels will rotate less for every MPH. So you will be going faster than you think. Plus it will look ridiculous IMO. Too much sidewall. I work at a tire shop....i can figure out exactly how much larger they are tomorrow as i dont feel like doing math at this time. I just bought some HANKOOK RS2 Z212 for track use in 225/50/16 front and 245/45/16 rear. those fit perfect. They were probably the stickiest street tires in that size. I wanted the bridgestone RE01-R though but they werent available in that size.
forget it . i did the stupid math. i cant resist math. The 245/45 sidewall is 110.25mm or 4.34''. The 245/50 sidewall is 122.5mm or 4.8''. So there's a difference of about .46''. Half inch. that's a lot. that means an inch over all.
The diameter of the 245/45 over all would be 24.68
the diameter of the 245/50 over all would be 25.6
interesting... i suppose i can stick with the 225-50 setup.. i just wanted to make sure i had the same contact size as the stock so-2's.. since they are supposedly more like a 245 size..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sprix! »</TD></TR><TR><TD CLASS="quote">You should also be aware that such a difference in height not only causes the speedo to be inaccurate, it could also possibly freak out your ABS system. </TD></TR></TABLE>
True. The S runs a larger rolling diameter up front than rear.
Right, I meant that the actual speed would be higher than indicated.
I've been running 25.7 inch high rear tires for a while now (275/40-17) and have not had any ABS issues (I track and Solo the car very often). I'm also running 225/4017 up front.
Last week I put new tires on my 16" rims and went with 205/55-16 and 245/50-16 on Kumho SPT. I did half a track-day on them before switching to the 17s, and didn't have any ABS issues either. Very progressive, though noisy.
The rear sidewall is a little larger, but it doesn't look ridiculous to me. It rides very well, probably smoother than the OEM S02 (but it's been a long time since I had those). Overall, I'm very happy with the 245/50-16 on the rear, especially for the price.
jdmspoonitr
Jul 30, 2010 11:41 AM
