Accord Feeling Sluggish with AC on...
Old Jul 1, 2007 | 06:27 PM
m1ndless's Avatar
* B A N N E D *
Default Accord Feeling Sluggish with AC on...
Latley, my 95 lx has been feeling pretty sluggish. When I accelerae, I noticed my needle does not move smoothly, but its barley noticable, and my car shakes when my AC is on, espically at red lights, I can feel it "shivering". I know my Rear Motor Mount probably needs replacing, it was about to go bad last time I checked, it looked almost cracked, but I couldnt really tell.
Would the rear motor mount be the problem? Or is it a combo of things? Or is it just it being 115 here in the middle of the day, and my car is struggling to keep the AC going?
Old Jul 1, 2007 | 09:13 PM
rival12's Avatar
Default Re: Accord Feeling Sluggish with AC on... (m1ndless)
The A/C Compressor robs power from the engine to get it going & moving, as does the power steering etc...
Rear Motor mount could be responsible for the shaking also, however, you might wanna check some plugs and wires, they are also a cause for vibrations. You could also invest in a stabilizing kit to smoothen out the engines power band, and distribution.
Old Jul 2, 2007 | 12:33 AM
YeuEmMaiMai's Avatar
milage on the car? might be time for you to sea foam that sucker
Old Jul 2, 2007 | 01:04 PM
m1ndless's Avatar
* B A N N E D *
Default Re: Accord Feeling Sluggish with AC on... (YeuEmMaiMai)
It has 139K miles on it right now. I only feel the bad shaking/vibrating when I am idling, is idling at like 800 rpms normal? Not sure if that had anything to do with it.
I was considering sea foam.. I checked my spark plugs and wires, everything looks good, not sure exactly what to look for though.
Do I just put it in the Gas Tank? Or do I need to put it in the injecotrs and stuff too?
Old Jul 3, 2007 | 12:32 PM
rival12's Avatar
With plugs and wires, you just have to make sure they are sparking, i.e. get some to turn the key, and check one plug at a time to make sure they are getting consistent spark.
Old Jul 3, 2007 | 09:00 PM
361 accord's Avatar
Default Re: Accord Feeling Sluggish with AC on... (rival12)
subscribed, mine lags big time with a/c
i would seafoam but i jsut spoent 125 on O2 sensors and stuff...
jdmturbo1127
Jun 13, 2008 03:10 PM
EG6SiR-T
May 10, 2008 10:02 PM
SOHC_MShue
31
Nov 24, 2003 08:55 AM
mingchi69
Aug 13, 2003 11:15 AM
