WTF is this? LS, installing Blox IM, nowhere to bolt this piece up....
Old Jul 1, 2007 | 06:25 PM
mahatma's Avatar
Default WTF is this? LS, installing Blox IM, nowhere to bolt this piece up....
What is this thing? Original IM from a '92 LS motor.
It has coolant running through it (2 ports)
Here's the Blox IM, nowhere to put this thing. Although it has the coolant nipple that attaches to 'the thing'
Also, the stock throttle cable bracket doesn't bolt up, the spacing isn't right. Guess I'll just drill another hole in the bracket to make it work...
Old Jul 1, 2007 | 06:27 PM
93supercoupe's Avatar
Default Re: WTF is this? LS, installing Blox IM, nowhere to bolt this piece up.... (mahatma)
bypass it, its only a fast idle thermal valve.
If ur car runs fine then it really wont cause problems, maybe a little in the cold.
Just connect the hoses from either end.
Old Jul 1, 2007 | 06:32 PM
nickromeo's Avatar
Default Re: WTF is this? LS, installing Blox IM, nowhere to bolt this piece up.... (93supercoupe)
i agree the fast idle thermo valve is a peice of ****
Old Jul 1, 2007 | 06:44 PM
mahatma's Avatar
Default Re: WTF is this? LS, installing Blox IM, nowhere to bolt this piece up.... (nickromeo)
i love it when the answer is exactly what you wanted to hear
thanks guys
Old Jul 1, 2007 | 07:23 PM
Blackturboteg's Avatar
yep same as my skunk 2.. manifold.. just use a nipple and a clamp to close the bottom one off and ull be all good... and yes u have to modify the throttle body cable holder... i had to wiht mine..
Old Jul 1, 2007 | 08:29 PM
Joseph Davis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe &raquo;</TD></TR><TR><TD CLASS="quote">bypass it, its only a fast idle thermal valve.
If ur car runs fine then it really wont cause problems, maybe a little in the cold.</TD></TR></TABLE>
Not if you set a colder high idle via IACV in your ECU.
Old Jul 2, 2007 | 04:32 AM
mahatma's Avatar
Default Re: WTF is this? LS, installing Blox IM, nowhere to bolt this piece up.... (Joseph Davis)
hold on, so i just connect them, or block them both off (at their origins)?
Old Jul 2, 2007 | 04:36 AM
I.C.C.'s Avatar
just use a piece of hose to loop them together
240punk
Jan 20, 2011 03:46 PM
saltypants
25
Mar 29, 2010 05:34 PM
4g4dcruisin
Jun 1, 2009 06:56 AM
ApolloSpeed
Sep 12, 2005 04:58 PM
Lshatchy91
Jun 7, 2004 11:54 AM
