What happens when the timing is off?
The distributor on my 88crx si was put on wrong. I switched the cabels back to the proper order 1342, but the car shakes pretty bad. Is something wrong, bent rods?
Sounds more like its misfiring, make sure you have the wires in the proper order. 1342 is the right order but make sure you are looking at the distributor right.
I probably didn't look at it right. isn't it
12
34
If your look ing at it from the front right fender.
or
24
13
What can be broken when the dizz is put on wrong?
12
34
or
24
13
Thanks rcauto. Thats exactly what i needed. Did i damage anything in the motor having the distributor in the wrong order?
taguchi09
Jun 11, 2011 04:52 PM
Ticket2ride21
Feb 22, 2006 07:51 AM
