cams for a gsr
unless im wrong most cams over stage one require dual valve springs and you should be ok. so if you are doing dual valve springs go for whatever. if you aren't sure ask the manufacture of the cams you are thinking about buying
rwautomotive
May 19, 2016 10:51 PM
