rear springs question..
Old Jun 30, 2007 | 11:53 PM
Fliplm0de's Avatar
Default rear springs question..
well my suspension setup is currently on tokico illuminas with some h&r sport springs.. i think the drop on the front is fine..however id like the rears to be a lower.. would you guys recommend cutting the springs?? i heard it worsens the ride.. or any other options i can look into.. instead of buying a new set of springs
Old Jul 1, 2007 | 12:26 AM
94 IntegraLS's Avatar
Default Re: rear springs question.. (Fliplm0de)
You should never cut your springs... If you wanted more ride adjustablilty you should have gotten GC's or a coilover set up.
Old Jul 1, 2007 | 12:44 AM
Doostur's Avatar
Geez... if you cut the springs and let the bouncing begin
Old Jul 1, 2007 | 05:24 AM
WhiteRicer's Avatar
If you want to do it right, it is well worth the money to purchase coilovers. This way you can adjust your ride height without sacraficing your ride quality. Also coilovers are nice because you can alway raise your car back up if you needed to!!!
Old Jul 1, 2007 | 06:03 AM
keep_up's Avatar
Default Re: rear springs question.. (WhiteRicer)
a buddy of mine works at saturn saab and what one of the mechanics and him did there was heated up the srpings with an acetealyn torch to lower it and u can even notice a difference in bouncyness and now his ride looks good!
Old Jul 1, 2007 | 06:19 AM
Madness's Avatar
Default Re: rear springs question.. (keep_up)
Heating a coil spring is the absolute wrong thing to do. It ruins the temper of the spring and destroys the spring rate. If you have to cut a coil, do it in a way such as to minimize the amount of heat put into the spring.
I personally don't think that there is anything wrong with cutting a little off of an aftermarket spring if you just need a little more or want to save $ , although I will also be the first to admit it isn't the ideal way.
Old Jul 1, 2007 | 07:37 AM
91redteg's Avatar
Default Re: rear springs question.. (Madness)
just order some cheap *** coilovers off ebay and throw those on the rear thatll be beter than cutting them
Old Jul 1, 2007 | 08:00 AM
Fliplm0de's Avatar
Default Re: rear springs question.. (91redteg)
hah i didnt wanna cut it int he first place anyway..so i guess i'll order some cheap ones off ebay how they dont' blow my shocks quick though
ej8ray
Suspension & Brakes
May 28, 2011 09:09 AM
CLIPHSET
Suspension & Brakes
Sep 9, 2009 01:58 PM
Suzukablue
15
Feb 16, 2005 05:57 PM
jdmspoonitr
Feb 24, 2004 01:38 PM
Hondasaurs
Apr 16, 2002 09:32 AM
