Uneven drop on H&R springs
I had my H&R sports installed 2 weeks ago and I just noticed that the rear driver side is lower than the rear passenger side. Is this normal a thing or was there something wrong on the installation or the springs itself? Help please...
Re: Uneven drop on H&R springs (1cleanEJ8)
When I was searching on H-T for info about springs and coilovers. I found that a few people noticed uneven drops with their springs. I think it's an issue with the other suspension components, like bushings, wearing unevenly.
reason i changed from coilovers to springs was the hassle of the drop being uneven and now i still get this. thanks for the info bro. i'll look into that
Re: (arnold1980)
i just searched and there's a couple of guys that has the same problem with H&R's. I'll give it another week or two before I check on it.
Re: (1cleanEJ8)
this isnt going to make any sence BUT...when you dropped the car off the lift/jack sometimes the shock gets hung up on that tube dealie....i dont know what im talking about...........I have H&R springs and tockio shocks w/ no problems...
totally normal bro...I have neuspeed race springs and its the same deal " rear pass side is higher then the rest of the car" I cant stand it! So i just got some skunk2 coil-overs so i can adjust it to how i like it...
lowering *springs* suck
coil-overs
coil-overs
Same problem here..drivers side is a tad bit lower then passenger side. Thats probably because there's always a driver so it maybe puts more wear on the driver side. Thats why I reccomend coilovers..you can accomodate the uneven drop
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1cleanEJ8 »</TD></TR><TR><TD CLASS="quote">I had my H&R sports installed 2 weeks ago and I just noticed that the rear driver side is lower than the rear passenger side. Is this normal a thing or was there something wrong on the installation or the springs itself? Help please...</TD></TR></TABLE>
NO!!! ITS NOT NORMAL. Well after 2 wks and still uneven, yeah you have a prob. Reason why:
1. Shock on driver side is out
2. The spring on passenger side didn't go in its slot (normally it breaks in after driving but after 2 wks it should of already broken in)
Now the solution is just bring it back have them take it back out and inspect it, then reinstall it again.
Re: Uneven drop on H&R springs (JDM EK9)
bullcrap, its totally normal. my last civic sat maybe 1/4 inch higher on the passengers side, with both stock suspension and with brand new aftermarket suspension. i have seen and heard of many others being the exact same way. you should have used the adjustability of the coilovers to even your car out
i had coilovers for 4 yrs and this was the first time getting springs. a lot of people were againts coilovers because its bouncy, noisy and they said it throws away your alignment. anyway i'll live with what i have for now. as long as i know that i'm not alone with this problem then i'm good
Re: Uneven drop on H&R springs (milton)
at first mine was the same way, but the silver cup that holds the bottom of the spring was up like a bowl rather than facing down like the bowl was upside down. check which way its facing.
