Engine temp fluctuating during road trip from Portland, OR to Las Vegas PLS HELP!
Old Jun 30, 2007 | 08:45 PM
HuGEN's Avatar
Default Engine temp fluctuating during road trip from Portland, OR to Las Vegas PLS HELP!
Okay, I'm on my road trip to Las Vegas from Portland, OR. My little sister's 93 civic engine temp is fluctuating. from normal temp up to 3/4 sometimes almost up to redline then it stays there for few min or slowly goes down to normal or close to normal temp. This usually occurs during hill climbs and acceleration but sometimes it occurs at different times too. I went to an Autozone and bought a thermostat and replaced it at the store. I thought this would be the fix (since its cheap). After replacement and about 50miles the problem reoccurs. It was fine for a little bit then it starts to fluctuate again. I'm currently in Reno getting ready to go down to Vegas. Would this be safe? Things that I have notice are that the coolant resivoir is totally full and the radiator cheap is not that hot don't know if thats normal. I have driven the car about 600miles so far. What can cause this? I'm carrying a heavy load since I'm helping my sister move down to Vegas. Hope I made this clear enough.
BTW it's a 1993 Civic DX Automatic, water pump has been recently replaced as well as the thermostat.
Any help is greatly apprecitaed.
Old Jun 30, 2007 | 08:53 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: Engine temp fluctuating during road trip from Portland, OR to Las Vegas PLS HELP! (HuGEN)
how fast are you driving *honestly*
Old Jun 30, 2007 | 08:55 PM
HuGEN's Avatar
Default Re: Engine temp fluctuating during road trip from Portland, OR to Las Vegas PLS HELP! (oneludesol)
speed limit 60-65 sometimes 70 honestly. Any suggestion?
Old Jun 30, 2007 | 08:56 PM
HNP's Avatar
HNP
try the fan switch, it might be working at times only....and if u temp keeps goin up is not safe to drive far
Old Jun 30, 2007 | 08:57 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
I had a turbo sohc that did exactly what you are talking about, but at 75+ mph... To make it stop I would either slow to 70 or turn on the heat (make sure its on fresh air not recirc)
Old Jun 30, 2007 | 09:05 PM
HuGEN's Avatar
Default Re: Engine temp fluctuating during road trip from Portland, OR to Las Vegas PLS HELP! (HNP)
What should I do with the fan switch? Where is it located?
Old Jun 30, 2007 | 09:49 PM
HNP's Avatar
HNP
do a search on the fan switch, is right by the thermo...
KidZr0
19
Sep 1, 2011 01:28 PM
mherrcat
Mar 20, 2011 03:04 PM
daochihung
Jul 17, 2010 07:12 PM
litterbox
Mar 16, 2009 06:50 AM
bumthology
11
Dec 11, 2004 11:23 AM
