Help with injectors
Old Jun 30, 2007 | 06:28 PM
firecivicman's Avatar
Default Help with injectors
I have a 1993 honda civic dx. it had the 1.5 in it. i put a d16z6 in it and im not getting power to my injectors. why? please help!!!
Old Jun 30, 2007 | 06:41 PM
93baggedcivic's Avatar
Default Re: Help with injectors (firecivicman)
im haveing the same prblem i rebuilt my motor d15 and i dont have power tot he injectors or spark.check all your grounds,alt fuse,fuel injector relay(under dash driver side grey box)and how do you know your not getting power tot he injectors.
Old Jun 30, 2007 | 07:56 PM
slowcivic2k's Avatar
Default Re: Help with injectors (93baggedcivic)
Check to make sure you have spark first, the PCM will cut the fuel until it knows there is spark to ignite it.
Turn the key in the ON (II) position and check for 12V at the BLK/YEL wire on your distributor harness, also check some other no spark threads in here, I've done a lot of writeups on this subject.
Old Jun 30, 2007 | 08:40 PM
i went over everything we ran two wires to all my injectors one for power and one for ground. we gave it a on off kinda deal and it almost fired up. we hooked up two wires an a light in the harness to figure if we were getting power you can also use a niod light
Old Jun 30, 2007 | 08:41 PM
i am getting spark
builtsinglecam
Mar 8, 2011 10:09 PM
DC2R96
Mar 3, 2011 06:09 PM
Acidcrakker
Nov 17, 2007 04:11 AM
mintylouse
Aug 5, 2007 09:08 PM
brad98_teg
Feb 22, 2006 03:39 PM
