CEL 67 Question (gutted cat)
Old Jun 6, 2002 | 10:29 PM
NickGSR's Avatar
Default CEL 67 Question (gutted cat)
I gutted out my cat the other day and my cel came on so i reset the ecu and it went away but it came back today. I checked it and it was 67 just as I thought it would be. My question is will that make the car run rich or retard the timing or anything? I'm going down to the track tomorrow and don't want that **** to be affecting my car's performance. Any help is appreciated.. btw, does anyone know an easy fix for that?
Old Jun 6, 2002 | 10:37 PM
TakaIntegra's Avatar
Default Re: CEL 67 Question (NickGSR)
Your CEL will always be on because your gutted cat. Take out the o2 sensor and wrap it with tin foil. Then wrap it with eletrical tape. Zip tie it onto the sway bar.
Plug up the hole in the cat. Reset the ECU and your CEL will never come back on.
Old Jun 6, 2002 | 10:47 PM
NickGSR's Avatar
Default Re: CEL 67 Question (TakaIntegra)
but if i don't do anything about it (going turbo in August) will it run perfectly normal? I can deal with the light until August when i put on the DP w/my hondata.
Old Jun 7, 2002 | 07:06 AM
NickGSR's Avatar
ttt
Old Jun 7, 2002 | 07:28 AM
No it will always be on. Do what I suggested and you will be fine.
Old Jun 7, 2002 | 07:56 AM
X2BOARD's Avatar
Will the CEL affect anything as he asked b4 ? Increase the fuel or take away spark (retard timing) ?
Old May 21, 2003 | 09:04 PM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TakaIntegra &raquo;</TD></TR><TR><TD CLASS="quote">Your CEL will always be on because your gutted cat. Take out the o2 sensor and wrap it with tin foil. Then wrap it with eletrical tape. Zip tie it onto the sway bar.
Plug up the hole in the cat. Reset the ECU and your CEL will never come back on.</TD></TR></TABLE>
so the tin foil trick actually works? just wrap it up with foil and let it hang there?
Old May 21, 2003 | 11:10 PM
romeo619romeo's Avatar
Default Re: CEL 67 Question (civicdxtyper)
wouldnt it still go back on? cuz its not reading anything? im assuming this is refering to the 2nd o2
korney
Nov 4, 2006 10:02 PM
Kronn 98SH
Jan 12, 2005 12:26 AM
gear_e
13
Nov 2, 2004 08:33 AM
itr1244
Aug 26, 2004 07:46 PM
ajchen
Mar 26, 2003 08:23 AM
