How to tell if my clutch is going bad?
Old Jun 30, 2007 | 12:03 PM
95TEG's Avatar
Default How to tell if my clutch is going bad?
How can I tell if my clutch is going bad? It had 124K on it, never grinds, has no problem shifting, but when I am slowing down, and step on the clutch to downshift or put it in neutral, the clutch makes a strange sound sometimes. Not a grinding sound, but like a thudding sound. I know thats a bad description, but I would love some feedback. Thanks.
Old Jun 30, 2007 | 12:15 PM
black92DA's Avatar
Default Re: How to tell if my clutch is going bad? (95TEG)
when my clutch was going bad it would rev up to 3k before my car would actually start moving
Old Jun 30, 2007 | 02:14 PM
MonsterB20Ek's Avatar
pull up the handbrake as much as u can put it in 1st gear and pop the clutch if it takes a few seconds to turn off its going bad..
Old Jun 30, 2007 | 03:07 PM
posHonda's Avatar
when my clutch was going bad i could just floor it in fifth and it started slipping and the revs went crazy
Old Jun 30, 2007 | 03:25 PM
DAmnquickDA's Avatar
Default Re: (iVteC_PoWeR)
sounds like your clutch is going bad in a way other than normal wear and tear/slipping. might want to take the tranny off and check. if it makes noise when pushing the pedal in, could be a bad pilot bearing
Old Jun 30, 2007 | 06:11 PM
95TEG's Avatar
Default Re: (DAmnquickDA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAmnquickDA &raquo;</TD></TR><TR><TD CLASS="quote">sounds like your clutch is going bad in a way other than normal wear and tear/slipping. might want to take the tranny off and check. if it makes noise when pushing the pedal in, could be a bad pilot bearing</TD></TR></TABLE>
Is this the only way to know, by removing the tranny?
Old Jun 30, 2007 | 06:18 PM
numbnuts22715's Avatar
its the only real way to know for sure...
you need to inspect everything, make sure nothing is messed up.
Old Jun 30, 2007 | 06:21 PM
Default Re: (numbnuts22715)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 &raquo;</TD></TR><TR><TD CLASS="quote">its the only real way to know for sure...
you need to inspect everything, make sure nothing is messed up.</TD></TR></TABLE>
X2
Jaydeep
Oct 23, 2009 07:40 AM
Ser1N
Dec 4, 2007 07:29 AM
sageuvagony
Jul 16, 2007 12:30 AM
kihun_cha
Mar 22, 2007 05:16 PM
sinfulDB1
May 5, 2003 09:26 AM
