h22 compression test??? GOOD or BAD??
Old Jun 30, 2007 | 08:22 AM
BIG T's Avatar
Default h22 compression test??? GOOD or BAD??
ok so here is the deal i am looking into buying a used 98 H22 for my EG and was wondering what good compression is?? they said that it pulled 160 across all 4 cylinder just wondering what you guys think about those numbers??
Thank YOu
Old Jun 30, 2007 | 08:35 AM
Missing Gears's Avatar
Default Re: h22 compression test??? GOOD or BAD?? (BIG T)
i think you should do the compression test yourself before you buy the motor.
Old Jun 30, 2007 | 09:15 AM
fast_honda's Avatar
Default Re: h22 compression test??? GOOD or BAD?? (Missing Gears)
Yeah, go buy a compression tester for $20 and do it yourself, it's really really easy. I actually did mine yesterday to check up on my engines health after a year of having it, and it was 220 on all the cylinders. Different guages can give different readings, so go get yourself one. Remember to pull the ECU fuses from the inside fusebox when doing the compression test, this will deactivate the fuel pump. And disconnecting the 2 distributor plugs is a good idea too.
Old Jun 30, 2007 | 09:51 AM
Default Re: h22 compression test??? GOOD or BAD?? (fast_honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast_honda &raquo;</TD></TR><TR><TD CLASS="quote"> And disconnecting the 2 distributor plugs is a good idea too.</TD></TR></TABLE>
not only a good idea, but it will keep you from burning up the coil.
dont forget to hold the throttle open and also crank each cylinder the same number of revolutions. the compression numbers dont have to be extremely high but it is important that they are somewhat even across, within 10-15 psi of eachother.
Old Jun 30, 2007 | 10:07 AM
I-4's Avatar
I-4
umm 160 is garbage no offence. should be in the 200s
Old Jun 30, 2007 | 11:20 AM
BIG T's Avatar
that is just it the motor is not in the car
Old Jun 30, 2007 | 11:27 AM
lude98SH's Avatar
your looking for consistency rather than peak numbers however there is a min spec
Old Jun 30, 2007 | 11:33 AM
lude98SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Missing Gears &raquo;</TD></TR><TR><TD CLASS="quote">
dont forget to hold the throttle open and also crank each cylinder the same number of revolutions. the compression numbers dont have to be extremely high but it is important that they are somewhat even across, within 10-15 psi of eachother.</TD></TR></TABLE>
Are you talking about the wiring in the primart circuit that runs to the coil and the plug coming out of the ingition coil that goes to the cap ?
Old Jun 30, 2007 | 11:42 AM
BIG T's Avatar
Default Re: h22 compression test??? GOOD or BAD?? (lude98SH)
what is that MIN SPEC
Old Jun 30, 2007 | 11:48 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
...within 10-15 psi of eachother.</TD></TR></TABLE>
Up to 28 psi variation is acceptable (though I'd be worried)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BIG T &raquo;</TD></TR><TR><TD CLASS="quote">what is that MIN SPEC</TD></TR></TABLE>
135 psi is min spec..
Old Jun 30, 2007 | 12:00 PM
BIG T's Avatar
Default Re: h22 compression test??? GOOD or BAD?? (cb7-R)
is it say to assume the motor is getting on with it;s life then
redline7
Nov 7, 2008 07:49 AM
xd69
Mar 7, 2006 12:10 PM
steveobb4
Aug 19, 2005 11:55 AM
fafsa
Dec 3, 2004 12:10 PM
2old_honda
Apr 12, 2002 01:25 AM
