Manual transmission fluid change.
Hey guys, it's about time to change my b16 tranny fluid. I searched around, but nothing was really clear. Drain, top, run all the gears then drain and then top?
Run the fluid second time to get all the metal shavings off and then top/fill at about 1.9 quarts or fill 'till overflow? What mtf do you guys use/recommend on using? honda or gm syn's?
Any help or pointers would be greatly appreciated!
Thanks in advance.
Vn712
Thanks in advance.
Vn712
GM Syncro is GARBAGE!!!
I have a new tranny with less than 50k on it....Put the GM trash in it and had a terrible 3rd and 4th gear grind in less than a week.....
Switched back to HMTF and the grinds were gone instantly. Feels great!! I truely believe the only thing the GN **** is good for is hiding problems and ruining good trannies.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote">The grind won't go away, it will only be masked.
$400+ to fix.
got a Y21 and a YS1 on the bench right now.......</TD></TR></TABLE>
We dont know that for sure.......Like I said before. My tranny is 100% in perfect working order. I had HMTF in it...needed a change so I tried the syncoshit and it felt like crap from the start and started to grind. Went back to honda MTF and the grinds imediately vanished. The syncroshit is noticably thicker too. I dont like it one bit.
$400+ to fix.
ive run syncromesh for about 50,000miles in my type r transmission. no problems as a matter of fact before i used the syncromesh it didnt feel as smooth. may i ask why you would drain and look for metal shavings if the tranny was just fine to begin with?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bejita »</TD></TR><TR><TD CLASS="quote">
We dont know that for sure.......Like I said before. My tranny is 100% in perfect working order. I had HMTF in it...needed a change so I tried the syncoshit and it felt like crap from the start and started to grind. Went back to honda MTF and the grinds imediately vanished. The syncroshit is noticably thicker too. I dont like it one bit.</TD></TR></TABLE>
What? Tell me that you're not trying to argue this with Bone
Thanks to everyone that replied and hope everyone had a great 4th.
Anyways, I wanted to change my fluid because I've been driving for about 30K of harsh driving. I just did a recent tune up (cap, rotor,plugs,wires, seafoamed) and just wanted to change the fluid.
Again, thanks to everyone that stay ON TOPIC.
Mike1995HondaPrelude
Sep 1, 2007 07:38 AM
integraboi1010
May 20, 2004 11:08 AM
