what is wrong when my rpm's is way below
Old Jun 29, 2007 | 06:11 PM
tosantoyo's Avatar
Default what is wrong when my rpm's is way below
i after its been runin awhile
Old Jun 29, 2007 | 06:18 PM
HXvtec's Avatar
Default Re: what is wrong when my rpm's is way below (tosantoyo)
how low?
Old Jun 29, 2007 | 06:19 PM
Padawan's Avatar
Darth ModerVader
You're really going to have to restate the question, as it's impossible to determine what you're asking.
Old Jun 29, 2007 | 06:21 PM
tosantoyo's Avatar
Default Re: what is wrong when my rpm's is way below (HXvtec)
its like on tha last line or jus alittle above tha las one
Old Jun 29, 2007 | 06:59 PM
slowcivic2k's Avatar
Honda states that 500rpm idle is acceptable, however I believe that is far too low for any car, as it would make next to no oil pressure. First thing I would check is your PCV valve. The engine gets almost 40% of its idle air from the crankcase vent, and if this valve is stuck closed, the IACV will compensate the best it can until it can no more, which most of the time isn't enough to maintain a good idle. 750rpm hot idle is a good idle.
A car should idle around 450rpm with the IACV unplugged, if it stalls when you disconnect it, I would suspect PCV. If it slowly peters out and stalls, IACV is probably clogged, unbolt and shoot brake parts cleaner in there. Also ensure that the throttle plate is not plastered with crap. if it is remove and clean it. Verify your repairs by unplugging the IACV, the car should maintain a crappy 450rpm idle without it, indicating a good PCV system.
Old Jun 30, 2007 | 01:47 PM
tosantoyo's Avatar
Default Re: what is wrong when my rpm's is way below (slowcivic2k)
thanks
footstinker
Nov 6, 2010 01:09 AM
crazykid9137
Aug 18, 2007 02:09 PM
Marble
Nov 18, 2004 05:51 AM
killa_lude
Aug 16, 2003 08:33 AM
