oil light blinking
Old Jun 29, 2007 | 05:50 PM
mattcalica's Avatar
Default oil light blinking
okay, so my oil pressure light is blinking in my dash. I hooked up a gauge to the oil line feeding my turbo and it reads 40 psi at idle (kinda high?), so I know that there is pressure. Is it just a band sensor? The car didnt have any problems before, but its been sitting for a few months. I made sure to prime the motor first. If the gauge is reading pressure, then I have nothing to worry about, right?
Old Jun 29, 2007 | 06:07 PM
cleanda6's Avatar
40 sounds bout right psi check if ur fluid levels are good thats what usually happens
Old Jun 29, 2007 | 06:57 PM
mattcalica's Avatar
Default Re: oil light blinking (mattcalica)
just changed my oil
Old Jun 29, 2007 | 08:41 PM
numbnuts22715's Avatar
Default Re: (cleanda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cleanda6 &raquo;</TD></TR><TR><TD CLASS="quote">40 sounds bout right psi check if ur fluid levels are good thats what usually happens </TD></TR></TABLE>
you can be missing like 2.5 quarts of oil and still have perfect oil pressure...
Is there any way you can check the oil pressure at the block?
It kinda sounds likea faulty sensor to me, if youre not getting pressure to the block, then the light should just be on, not blinking.
Old Jun 30, 2007 | 06:23 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I had a problem one time where my oil light was flashing while the car was running. At the same time I also had a problem where my battery light would come ON when the car was OFF, and it would stay on until the next time I started the car. Then the battery light would go off.
As weird as it sounds, replacing the alternator fixed both warning light problems.
joker4096
May 2, 2010 08:27 PM
Firefoxracer
Jul 24, 2007 03:55 AM
shrirag
Apr 11, 2007 09:55 AM
elnoyl
May 19, 2005 04:54 PM
96b18c
Feb 23, 2003 10:45 PM
