Intercooler piping question
Here is what i have so far. I need to connect the turbo outlet to the top of the intercooler. I know it's hard to see but I have a sidemount where my air conditioner used to be and the hole is in the top of the pic. There's about a gap of 6-8" from the 2 points. I figured on using the stock intercooler piping from the eclipse but unfortunatly i don't have any. It is 2" to 2". I'm going to be running about 9psi on a t28. Anyone have any suggestions on how i can EASILY and CHEAPLY connect these two. I would use hard pipes but the two holes are cocked and I need something a little more flexible.
[IMG]
[/IMG]
[IMG]
that looks like a pretty tough bend. Try to see if any local muffler shops have any 2" piping that you can use. Good luck.
depending on where you live...i live in PA we have A & A auto parts which i work at...i had a similar problem i just looked in some of our books and found a couple of short 90" elbows and welded them together the way i needed...good luck
