Intercooler piping question
Here is what i have so far. I need to connect the turbo outlet to the top of the intercooler. I know it's hard to see but I have a sidemount where my air conditioner used to be and the hole is in the top of the pic. There's about a gap of 6-8" from the 2 points. I figured on using the stock intercooler piping from the eclipse but unfortunatly i don't have any. It is 2" to 2". I'm going to be running about 9psi on a t28. Anyone have any suggestions on how i can EASILY and CHEAPLY connect these two. I would use hard pipes but the two holes are cocked and I need something a little more flexible.
[IMG]http://img2.putfile.com/thumb/6/17917505229.jpg[/IMG] |
Re: Intercooler piping question (Tzarinque)
that looks like a pretty tough bend. Try to see if any local muffler shops have any 2" piping that you can use. Good luck.
Re: Intercooler piping question (jmm96gsr)
thanks, i'll keep an eye out. Anyone have an other suggestions?
depending on where you live...i live in PA we have A & A auto parts which i work at...i had a similar problem i just looked in some of our books and found a couple of short 90" elbows and welded them together the way i needed...good luck
