i dont know if its my tranny or the bearing
Old Jun 29, 2007 | 04:37 PM
STP_crx123's Avatar
Default i dont know if its my tranny or the bearing
this is my suitation i was in the highway in 4 gear and i down shift to 3rd all od a sudden i couldnt put it in 4th, 5th gear and reverse i wondering if its my tranny that got mess up or the bearin that pop.........
Old Jun 29, 2007 | 05:30 PM
97Ej6mike's Avatar
could be a number of things. If a clutch's master/slave cylindar setup is low on fluid, it wont allow th clutch to depress all the way, causing you to have hard times getting in and out of any gear. From the sounds of your situation it may be tranny related, bad synchro or something. Im no tranny expert myself. What kind of motor are we talking about here? year? mods? more info.
Modified by 97Ej6mike at 6:44 PM 6/29/2007
Old Jun 29, 2007 | 05:52 PM
STP_crx123's Avatar
Default Re: (97Ej6mike)
is a ls motor with a b16 tranny
Old Jun 29, 2007 | 06:52 PM
Mista Bone's Avatar
D Tranny Guru
bearings bad from running low on oil, or debris has clogged the oil ports, again dry bearings.
NOT gonna be cheap!
civic-rice-rockit
15
Feb 19, 2009 02:19 PM
TurboGoKart
Jun 7, 2006 04:34 AM
jdmwannabe3
Apr 26, 2006 11:01 AM
EnzoSpeed
Nov 6, 2005 06:47 PM
