Can you run a walboro 255 intank on a stock internal motor..??????
Old Jun 29, 2007 | 02:51 PM
4gencivicef9's Avatar
Default Can you run a walboro 255 intank on a stock internal motor..??????
I have put this in my car and it would start then die, I have a b and m FPR adjusted to stock settings but still curious if it should do this
Old Jun 29, 2007 | 02:52 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: Can you run a walboro 255 intank on a stock internal motor..?????? (4gencivicef9)
If your motor is stock leave the stock fuel pump.
Getting more fuel doesn't do **** without getting more air.
You're car dies likely because your over saturating it with fuel
Old Jun 29, 2007 | 03:08 PM
turbociviccoupe's Avatar
Default Re: Can you run a walboro 255 intank on a stock internal motor..?????? (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">If your motor is stock leave the stock fuel pump.
You're car dies likely because your over saturating it with fuel</TD></TR></TABLE>
werd
Old Jun 29, 2007 | 04:27 PM
Elevorett's Avatar
no, you will not over saturate, because that is what the fuel return line is for. any excess fuel will simply drain back into the tank.
Old Jun 29, 2007 | 05:52 PM
Ek Forever y0!
Default Re: (Elevorett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elevorett &raquo;</TD></TR><TR><TD CLASS="quote">no, you will not over saturate, because that is what the fuel return line is for. any excess fuel will simply drain back into the tank.</TD></TR></TABLE>
The fuel return line can only return so much. Have you seen how narrow that line is?
Old Jun 29, 2007 | 06:24 PM
Syndacate's Avatar
Default Re: (ek forever guy)
The fuel return line can only return so much. Have you seen how narrow that line is?</TD></TR></TABLE>
Naw, it needs an assload to "overload" the fuel rail. It'll all drain back to the tank if it's only a 255.
@ OP:
If it's the stock motor it's completely unecessary. Though you won't have any problems caused by it as long as you adjust the FPR to be to its stock pressure range.
Old Jun 29, 2007 | 07:00 PM
LunarEclipse's Avatar
Default Re: (Syndacate)
you'd be surpised how much a 255 walbro can put out.....my old car was boosting 28psi on a 60-1 turbo and it was still running rich....they put out alot of juice... id suggest downgrading back to stock or if you really want to put something, run a 190 Walbro instead....
Another option is simply just run slightly bigger injectors and keeping the stock pump in....
Old Jun 30, 2007 | 01:19 PM
Default Re: (LunarEclipse)
thanks
schpiel
Jul 10, 2008 01:08 PM
TurboB16A300Hpteg
Feb 25, 2008 06:08 PM
slodel
Sep 27, 2006 07:12 PM
trooper0641
23
Apr 6, 2005 12:51 PM
codeh22a4
Jul 7, 2004 11:36 AM
