Header flange thickness
Old Jun 29, 2007 | 02:05 PM
vtec_lude's Avatar
Default Header flange thickness
Hi guys,
I'm planning to make a header flange. I'm not too sure what material I'm going to use but probably stainless steel. I was wondering, would a 10mm header flange be ok to use?
Thanks for the help
Old Jun 29, 2007 | 02:18 PM
9bells's Avatar
OG Fabricator
Default Re: Header flange thickness (vtec_lude)
N/A header, maybe. Stainless will warp more.
I go 1/2 on almost everything. It may be overkill, but it will last.
Old Jun 29, 2007 | 03:54 PM
vtec_lude's Avatar
Default Re: Header flange thickness (9bells)
So would mild steel be less likely to warp?
Old Jun 29, 2007 | 04:06 PM
weiRtech's Avatar
OG Fabricator
i have no experience with ss head flanges but 3/8" or 1/2" has worked fine for me.
Old Jul 2, 2007 | 08:25 AM
89crxhf's Avatar
Default Re: (weiRtech)
Almost all the flanges i cut for local turbo manifold makers here are 1/2 inch mild steel,
on rare occassion do i make 3/8 inch flange for them. I am not a welder but i would recomend 1/2 inch steel wiether it be mild or stainless.
Tom
Old Jul 2, 2007 | 02:23 PM
vtec_lude's Avatar
Thanks for the replies. I'll probably go for mild as it seems the better option.
pitchblacksol
Welding / Fabrication
Dec 12, 2006 11:00 PM
luv2drivecrx
Oct 23, 2005 08:03 AM
luv2drivecrx
Oct 19, 2005 02:14 AM
lovitalracer
11
Mar 25, 2005 07:10 PM
ruzzy7
Nov 22, 2004 01:48 AM
