pcv valve - Black box **need helms page**
Old Jun 29, 2007 | 06:48 AM
Mr_ET's Avatar
Default pcv valve - Black box **need helms page**
Hi everyone, I recently turboed my civic and I am having some trouble with my oilpan gasket, rear main seal and possible my valve cover gasket.
I also have a bit of an erratic idle once the car is warmed up going from 900 and steady to 500 and almost dying every minute or so.
I am not sure but I think I may have an issue with my pcv valve not opening and closing as it should and I would like to have a look at it and possible clean/replace it.
The car is only making about 140whp and it's a 6 psi on a t3/t04e 46 trim turbonetics so my understanding is a valve cover breather and a good functioning pcv system should suffice.
Does anyone have a printout from a helms manual of where I can find the pcv valve on a sohc zc or (d16a6) and possibly how to disconnect it without breaking it.
I searched and the older archived threads don't have pics that work anymore.
Thx!
Old Jun 29, 2007 | 07:14 AM
jlicrx's Avatar
Default Re: pcv valve - Black box **need helms page** (Mr_ET)
the PCV valve is behind the fuel rail right up on top - follow the large hose coming off the front of the intake manifold (in the center between the 2 smaller hoses) which goes to the PCV valve
Old Jun 29, 2007 | 07:48 AM
Mr_ET's Avatar
Default Re: pcv valve - Black box **need helms page** (jlicrx)
is it better to get access to it from the bottom or from the top?
I currently have the downpipe off as well as the bracket between the block and intake manifold.
If I go at it from the top do I have to remove the fuel rail?
Old Jun 29, 2007 | 08:24 AM
jlicrx's Avatar
from the top (this is SOHC ZC VTEC, but they are all about the same)
Old Jun 29, 2007 | 09:19 AM
Mr_ET's Avatar
can't see the image from work but thx I will check it out tonight!
Any precautions to make sure not to break the valve and can I clean it with brake cleaner?
Old Jun 29, 2007 | 09:24 AM
cr-x-91's Avatar
and it doesnt open and close..its a one way check valve...
Old Jun 29, 2007 | 09:30 AM
ILcrxsi1's Avatar
I tell doctors what to do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_ET &raquo;</TD></TR><TR><TD CLASS="quote">can't see the image from work but thx I will check it out tonight!
Any precautions to make sure not to break the valve and can I clean it with brake cleaner?</TD></TR></TABLE>lol, just pull it out. use carb cleaner
edit: or **** just buy a new one
Old Jun 29, 2007 | 09:43 AM
N_A_is_best's Avatar
Default Re: pcv valve - Black box **need helms page** (ILcrxsi1)
under boost how would you run the pcv lines wouldnt it pressureize the bottom end more?
Old Jun 29, 2007 | 03:57 PM
Crx Jimmy's Avatar
Default Re: pcv valve - Black box **need helms page** (N_A_is_best)
just run the hose to a catch can and vent it to the atmosphere, forget the PCV valve
Old Jun 29, 2007 | 04:01 PM
Mr_ET's Avatar
Default Re: pcv valve - Black box **need helms page** (Crx Jimmy)
bot wouldnt a working pcv valve and black box with a breather off the vc be enough at this low boost lvl?
A friend had the same engine in the same car with the same system and he was making about 50whp more and never had this issue
Jimhvis
Mar 25, 2009 05:53 PM
vteg98
Oct 24, 2006 07:05 PM
Marcos
Apr 12, 2003 06:02 AM
SurferX
Aug 28, 2002 04:36 PM
