My engine power drops when I push the throttle more than cruising HELP!!!!
Old Jun 6, 2002 | 07:57 PM
Bgladfelter's Avatar
Default My engine power drops when I push the throttle more than cruising HELP!!!!
On my way home tonight from Traffic school after I turned out onto the road I started accelerating and my RPM's on my tach dropped to zero and I had no power. My engine was still running but it kept bouncing between 0-250. When I let of the gas the whole way it slowly started rolling but when I pushed the throttle past a certain point it would drop to zero and start jerking the car. I could still shift and everything, but did the same in every gear! As soon as I barely pushed the throttle it would jerk around. I made it about half way home by backroads doing about 30 in 3rd before I pulled into an empty restaurant parking lot. I reset the ECU and then started driving around the parking lot. It still did the same thing so I started home. Slowly as I got home I could increase throttle w/o it dropping all power and as I was getting on my road I tried Full throttle and it worked great. No prob, went to 7K and not a peep of trouble. So I road tested it to where I was supposed to meet some friends. It work fine there. On my way home afterward it started it again but stopped after about 3 min.
Anybody have any ideas? My O2 sensor is out, could this be a culprit? Or is it my coil or fuel pump?
Any suggestions would be helpful.
Cliff notes: Pushed gas more than a hair RPMS drop to 0 on tach, and no foward movement. After about 20 min was fine, and then later was doing it again.
Brian
Old Jun 6, 2002 | 08:33 PM
raene's Avatar
Default Re: My engine power drops when I push the throttle more than cruising HELP!!!! (Bgladfelter)
Def sounds like fuel pump... it seems to kick out and then drive normally again, right?
Old Jun 6, 2002 | 08:34 PM
Default Re: My engine power drops when I push the throttle more than cruising HELP!!!! (raene)
yea
Thats what 1 mechanic that my dad knows guessed.
But it was fine after awhile. Is that normal for it to mess up and then work?
Old Jun 6, 2002 | 08:56 PM
raene's Avatar
When it's dying, yes. I had it do this six or seven times on different occasions before I figured out what it was. After I replaced mine problem solved
I actually drag-raced a few times with the pump dying, before I knew what it was.
Old Jun 6, 2002 | 09:01 PM
thanks man. Greatly appreciated. Time to go looking for a fuel pump.
Brian G.
EnjoiHonda
May 8, 2014 10:04 AM
Hardedge
May 16, 2009 07:38 PM
notstock93
Sep 1, 2004 09:20 PM
slyph777
Dec 14, 2002 11:22 AM
Bgladfelter
Jun 6, 2002 09:30 PM
