Stock Clutch Life
Old Jun 29, 2007 | 03:45 AM
K20Z1iVTEC's Avatar
Default Stock Clutch Life
hey guys i have an 06 rsxs cai, cat back, n very soon hondata reflash it has about 18k on it. i plan on bring my car to the track to see what i can get it to run. but after running my car at the track im sure the clutch life will b shortened. so my question to u guys it how long did ur stock clutches last u after the abuse u guys put it thur?
Old Jun 29, 2007 | 10:39 AM
eMpAtHy's Avatar
Default Re: Stock Clutch Life (K20Z1iVTEC)
i have a friend on HT that had his stock clutch until about 120,000 miles. Although, his car was stock
Old Jun 29, 2007 | 11:14 AM
scmil95eg's Avatar
I put 168,000+ on the del Slo's clutch and there was still 30-40% left when I replaced it.
There's 100,000+ on the EP3's right now, still nice & tight.
Old Jun 29, 2007 | 11:20 AM
Chris.'s Avatar
Honda-Tech Order of Merit
Default Re: Stock Clutch Life (Thomas Jenkinson)
my friends integra has about 200k on the original clutch and its still working fine.
Old Jun 29, 2007 | 11:47 AM
phthalo's Avatar
GDD4LIFE
Default Re: Stock Clutch Life (4F CHR!S)
i know a kid that drove an accord and within like two years he replaced the clutch four times hahaha
Old Jun 29, 2007 | 02:08 PM
GradyDC5's Avatar
Replaced mine at 90k but could have drove more miles. It was only slipping in 6th under full load.
Old Jun 29, 2007 | 07:38 PM
IntegrasAreBest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4F CHR!S &raquo;</TD></TR><TR><TD CLASS="quote">my friends integra has about 200k on the original clutch and its still working fine. </TD></TR></TABLE>
wow go honda
Old Jun 29, 2007 | 07:53 PM
Rev4Ever's Avatar
My last car I put 40K on it before I sold it and the clutch was totally fine and I beat the hell out of the clutch.
Old Jun 30, 2007 | 09:47 AM
The Bagel's Avatar
Default Re: Stock Clutch Life (Rev4Ever)
Had to change my EP's clutch at 70k miles because a piece of the pressure plate broke off. Otherwise I usually get 100k+ out of a clutch. Replaced with a Sachs clutch. Good for another 70k at least.
Old Jun 30, 2007 | 11:35 AM
Rev4Ever's Avatar
Default Re: Stock Clutch Life (The Bagel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Bagel &raquo;</TD></TR><TR><TD CLASS="quote">Had to change my EP's clutch at 70k miles because a piece of the pressure plate broke off. Otherwise I usually get 100k+ out of a clutch. Replaced with a Sachs clutch. Good for another 70k at least. </TD></TR></TABLE>
"Sachs," never heard of that brand
Old Jun 30, 2007 | 12:21 PM
The Bagel's Avatar
Good stock replacement.
Old Jun 30, 2007 | 12:46 PM
Unbreakable6161's Avatar
this is such a dependent factor, all depends on how you drive the car son.. Don't worry about it, the car only has 18k miles, plus when you DO replace it you can get a lighter flywheel/ACT clutch.
Old Jul 1, 2007 | 11:56 AM
9bells's Avatar
OG Fabricator
Default Re: Stock Clutch Life (Unbreakable6161)
I had over 150 passes on the stock clutch and 24,000 miles when the tranny blew. Clutch had slight blueing, but was fine for alot more use wear wise.
I was impressed. I dropped it at 4500-6000rpm most passes, twice each pass for the little burn-outs.
Clutch is great, tranny is window glass...
Old Jul 1, 2007 | 12:05 PM
risktypeS's Avatar
I'm not a firm believer in lightened flywheels, i'd rather not put a whole essay on why but lets just say it's more work on the car physics wise.
DO NOT go with ACT they are the shittiest clutches you'll ever buy. They SUCK majorly and would NEVER tell anyone to buy one. They break to easy and ACT will turn their back on you in a heart beat and blame it on you.
Old Jul 2, 2007 | 08:46 PM
Rev4Ever's Avatar
Default Re: Stock Clutch Life (risktypeS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by risktypeS &raquo;</TD></TR><TR><TD CLASS="quote">I'm not a firm believer in lightened flywheels, i'd rather not put a whole essay on why but lets just say it's more work on the car physics wise.
DO NOT go with ACT they are the shittiest clutches you'll ever buy. They SUCK majorly and would NEVER tell anyone to buy one. They break to easy and ACT will turn their back on you in a heart beat and blame it on you. </TD></TR></TABLE>
Good to know. Would you saw Exedy is a better choice? Why not put a light weight fly on at the same time?
Old Jul 4, 2007 | 07:41 PM
Slo_RSX's Avatar
You will be fine. I have tracked my car about 5-6 times with 10 psi and the stock clutch and its still holding up not to bad. (5000 kms since being boosted).
Old Jul 4, 2007 | 10:33 PM
Rev4Ever's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rev4Ever &raquo;</TD></TR><TR><TD CLASS="quote">
Good to know. Would you saw Exedy is a better choice? Why not put a light weight fly on at the same time?</TD></TR></TABLE>
BUMP
Old Jul 4, 2007 | 11:44 PM
Tadehi's Avatar
Schumacher '10 WDC
I personally think it is hit or miss, granted this is going off of only what I have read. But most people tend to have problems with ACT. Some though have had a great product from ACT, but I think that it is more dependent on your setup overall.
Old Jul 5, 2007 | 06:37 AM
Smith bPr's Avatar
i put about 85, 000 on mine with 45,000 of it being straight brutal abuse. Needless to say it was shot
Old Jul 5, 2007 | 07:15 PM
vtakef's Avatar
I have 113,xxx currently on the stock dc5 clutch and it still feels pretty good. But mine is stock.
Old Jul 5, 2007 | 11:44 PM
Rev4Ever's Avatar
Default Re: Stock Clutch Life (vtakef)
It sounds like you can get quit a bit out a stock clutch. Acura made quality clutches, to bad they didn't put some thought into fixing the grind problem.
Old Jul 6, 2007 | 09:56 AM
SilverDc2's Avatar
my friend has 115k and its starting to go out,
Old Jul 6, 2007 | 04:53 PM
risktypeS's Avatar
sorry didn't see the post. yes exedy is a better choice then ACT but i like competetion clutch. I don't like lightened flywheels because the drawbacks include an increased risk of over-revving when you miss a gear. Also, you'll have to rev the engine a bit more to get the car rolling from a dead stop, because you'll have less rotational inertia to trade off.
Old Jul 6, 2007 | 07:15 PM
posHonda's Avatar
sorry didn't see the post. yes exedy is a better choice then ACT but i like competetion clutch. I don't like lightened flywheels because the drawbacks include an increased risk of over-revving when you miss a gear. Also, you'll have to rev the engine a bit more to get the car rolling from a dead stop, because you'll have less rotational inertia to trade off. </TD></TR></TABLE>
i see why you dislike a lightened flywheel because of the over-revving problem but it does make rev matching faster and easier. i have an 8lbs flywheel on my gsr and after getting used to it now its easy to drive. driving a car with a stock flywheel and clutch to me just feels wierd now.
ONE*SICK*FERIO
Aug 19, 2009 05:08 PM
Trellis
Mar 15, 2006 07:04 AM
Schister66
Dec 4, 2005 02:22 PM
Don Jefe
May 18, 2005 12:52 PM
RCautoworks
25
Jul 8, 2003 10:15 AM
