gear poping - clutch problem?
Old Jun 29, 2007 | 02:12 AM
tchen415's Avatar
Default gear poping - clutch problem?
First gear pops out, doesnt stay. Only time it doesnt do this is when car is cold. My question is the clutch the problem?
Planning to do a clutch job anyways but im wondering if i can mix and match fly wheel, presure plate and clutch disk. I have a act prolite fly wheel and a act heavy duty presure plate. act organic disk as well.
I dont know much about clutches so im guessing just replace the clutch disk. Because plate and flywheel doesnt seem like it would go out. But my question is can i use another clutch with my existing plate and flywheel. ie exedy, stage 1 2 3 , oem ?
THANKS IN ADVANCE!!
Old Jun 29, 2007 | 07:05 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: gear poping - clutch problem? (t0EkNEE415)
WHat year Ford?
What Chevy Motor?
What Dodge tranny?
Without any of that info I will guess the input shaft bearing is GONE.
Old Jun 29, 2007 | 07:31 PM
tchen415's Avatar
sorry, i always forget the info. Its a 94 accord with h22a1 m2f4 tranny,
All started when the shift cable snapped and got stuck in first gear. I drove it about 5 miles on a on first ocasonally reving it high to go up hills. Got the cable changed and then it started poping out. We measured the shift cables and the old one was about a half inch longer. but im guessing the old one stretched and thats why it snapped.
Old Jun 29, 2007 | 11:00 PM
Mista Bone's Avatar
D Tranny Guru
Ive never worked on a cable shifted tranny, nor plan too.
Old Jun 30, 2007 | 12:53 AM
tchen415's Avatar
i mean trannys are different but should be in the same concept. I just need to know if i should be ripping apart the tranny or clutch. I just keep replacing things that i dont need to.
Eggman
May 1, 2018 11:04 AM
LilTeggy2011
Sep 23, 2010 02:04 PM
5thgearburnout
Sep 24, 2005 06:43 PM
jdminspiredDB8
Aug 30, 2005 04:39 PM
HS2G
Aug 22, 2004 07:34 AM
