b16 valve cover gasket
Old Jun 28, 2007 | 09:10 PM
97ek9's Avatar
Default b16 valve cover gasket
why would there be oil on the bottom of where my spark plugs go?
its not filled but there is some. and my oil is low.also one spark plug cap(cover) slides up,is that because of any compression through the tube of where the plugs go?
Old Jun 28, 2007 | 09:22 PM
Frozen E's Avatar
H-T White Ops
If you have oil in your plug holes, there's a good chance that the little grommets that go between your head and your valve cover are leaking. Get a valve cover gasket set. It should come with them.
Old Jun 28, 2007 | 09:26 PM
97ek9's Avatar
Default Re: (IslandSi)
what comes in the gasket set?
i just ordered a valve cover gasget today. Is there anything else i will need?
The computer @ autozone said it had grommets so should that fix the problem?
Old Jun 28, 2007 | 09:45 PM
Frozen E's Avatar
H-T White Ops
http://www.hondaautomotivepart...COVER
Look at the pic of the D16
You need four #4s
Old Jun 28, 2007 | 10:19 PM
97ek9's Avatar
if i would get the seals off my sohc stock engine, would they work the same or no?
Old Jun 28, 2007 | 10:25 PM
Frozen E's Avatar
H-T White Ops
dunno.
Old Jun 28, 2007 | 10:41 PM
RollinEk's Avatar
At least for the f22 and h22, the sohc spark plug gaskets wouldnt fit the h22 valve cover. Most likely the same case here.
Old Jun 28, 2007 | 10:50 PM
97ek9's Avatar
so if they do fit and with the new gasket will that be it?there cant be alot more things.
Old Jun 29, 2007 | 01:39 AM
Frozen E's Avatar
H-T White Ops
You bought a new valve cover gasket, so why not get a new set of these?
Old Jun 30, 2007 | 09:00 PM
t@rzan's Avatar
haha well im guessing you ganna need new gaskets
Old Jun 30, 2007 | 10:23 PM
Frozen E's Avatar
H-T White Ops
Default Re: (t@rzan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t@rzan &raquo;</TD></TR><TR><TD CLASS="quote">haha well im guessing you ganna need new gaskets</TD></TR></TABLE>
Tard
B16A JDM EG
Dec 4, 2007 03:44 PM
CalhounBoi
Oct 1, 2006 05:25 PM
saikouEF8
Apr 7, 2006 03:20 PM
redpeppers
Jul 15, 2005 04:17 AM
4genaccordfreak
Jan 4, 2004 01:07 PM
