need some help!!!!!!!!!
Old Jun 28, 2007 | 07:40 PM
94hondacivicvtec's Avatar
Default need some help!!!!!!!!!
my power steering went out a couple of weeks ago and now every time i hit a bump acellerate quickly, slow down fast or take corners it sounds like my power steering rack makes a poping sound. i dont think this is safe, what do you guys think? 94 honda civic ex stock.
Old Jun 28, 2007 | 07:45 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: need some help!!!!!!!!! (94hondacivicvtec)
What went out? The pump? Pulley? Belt? Lack of fluid?
Old Jun 28, 2007 | 07:49 PM
Default Re: need some help!!!!!!!!! (ek forever guy)
the seal in the pump, it started throughing oil all over my clean motor. also i pluged all the lines from the pump. there still is fluid in there, not alot cause i took some corners and it shot on my header. then i pluged it
Old Jun 28, 2007 | 08:02 PM
oh yeah i have searched and i can't find anything even remotely close to my situation.
Old Jun 28, 2007 | 08:19 PM
blkSi's Avatar
so replace the seal??
Old Jun 28, 2007 | 08:20 PM
Ek Forever y0!
Default Re: (blkSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkSi &raquo;</TD></TR><TR><TD CLASS="quote">so replace the seal??</TD></TR></TABLE>
or the pump, get one or both from a junkyard and swap it out. Shouldn't take you 30 minutes.
Old Jun 28, 2007 | 08:21 PM
motor_man's Avatar
Default Re: (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">
or the pump, get one or both from a junkyard and swap it out. Shouldn't take you 30 minutes.</TD></TR></TABLE>damn dude i like how u think....
Old Jun 28, 2007 | 08:22 PM
Ek Forever y0!
Default Re: (motor_man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by motor_man &raquo;</TD></TR><TR><TD CLASS="quote">damn dude i like how u think.... </TD></TR></TABLE>
&lt; Cheap bastard.
Old Jun 28, 2007 | 08:24 PM
motor_man's Avatar
&lt; Cheap bastard. </TD></TR></TABLE>...lol
Old Jun 28, 2007 | 08:35 PM
i would but all the junk yards around here dont have **** for my car, checked craigs list, none and then i called autozone and they want $179 for a rebuilt one. i'm just woundering if its about to go or something. the poping doesn't sound good but i can deal with it if its fine. just don't want to be driving down the street and have my steering lock up or something.
Old Jun 28, 2007 | 08:38 PM
Default Re: (94hondacivicvtec)
also i tossed the pump in the trash so replaceing the seal is out.
Ek Forever y0!
If it's just the seal, just buy the seal. P/s pumps are pretty simple. just take it off, and start taking it apart. Replace the seal, reassemble. What could happen? If you screw up, you'll be in the same boat as before.
Old Jun 28, 2007 | 08:41 PM
yeah i could of easily changed the seal but aint got the pump any more. so do you think it's still safe to drive?
Old Jun 28, 2007 | 08:43 PM
Ek Forever y0!
Okay, here's what you do. Find the moderator padawan, he sells p/s block off kits. It's the best way to eliminate p/s on out cars without swapping engines.
It's cheap, and works great.
Old Jun 28, 2007 | 08:47 PM
so just loop the rack with a breather and the poping will stop?
Old Jun 28, 2007 | 09:28 PM
is it still safe to drive. asked the question 3 times yet no answer please someone answer the question.
Old Jun 28, 2007 | 09:33 PM
Ek Forever y0!
The only thing you could really expletive up is your PS components and maybe your steering gear.
Old Jun 28, 2007 | 09:35 PM
so.........yeah for now? and steering gear? is that attached to the column or the rack?
blackj30_a
Sep 4, 2016 06:01 PM
thepel
May 20, 2008 02:39 PM
Prudz_lude
Jun 9, 2007 01:20 PM
h22aBB4
May 31, 2007 06:10 PM
