what do i use for a gasket (04' GSXR 600)???
Old Jun 28, 2007 | 06:52 PM
85's Avatar
85
Default what do i use for a gasket (04' GSXR 600)???
i got a friend replacing the oil pan on his 2004 GSXR 600 and i cant seem to find a gasket for it. do i use a liquid sealer or what? if so what kind?
Old Jun 28, 2007 | 07:00 PM
uneek4dr's Avatar
they dont have a gasket, use a silicone gasket maker
Old Jun 29, 2007 | 02:57 AM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
Default Re: (uneek4dr)
id order an oem gasket, or use permatex
Old Jun 29, 2007 | 03:27 AM
85's Avatar
85
Default Re: (Teddy Ruxpin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teddy Ruxpin &raquo;</TD></TR><TR><TD CLASS="quote">id order an oem gasket, or use permatex</TD></TR></TABLE>
thanks all...
Old Jun 29, 2007 | 05:24 AM
boostede36's Avatar
Just did this on my RR. Use a liquid gasket sealant from Honda. No gasket.
Old Jun 29, 2007 | 05:26 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: (boostede36)
permatex gasket never really holds unless it is used with conjunction of a gasket.
I hope you know that
So I would say that your best bet would be to use hondabond or what toyota uses on their oil pans
Old Jun 29, 2007 | 05:28 AM
.RJ's Avatar
.RJ
Default Re: (MugenHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda &raquo;</TD></TR><TR><TD CLASS="quote">permatex gasket never really holds unless it is used with conjunction of a gasket.
So I would say that your best bet would be to use hondabond or what toyota uses on their oil pans</TD></TR></TABLE>
You know that Hondabond is very similar to Permatex 'grey', right? Hondabond *is* easier to work with, but the end result is the same. There's other flavors out there that work just as well (toyota/subaru brand, threebond, etc).
Old Jun 29, 2007 | 06:32 AM
clean the surface properly and only use the permatex. that ***** works great. my buddy uses it for his oil pan gasket on his 13b, and if u know anything about rotary gaskets/seals youll understand.
Old Jun 29, 2007 | 07:23 AM
u n v kenny's Avatar
Hondabond works best.
Old Jul 1, 2007 | 03:22 AM
Johnny_Rocket's Avatar
clean the surface properly and only use the permatex. that ***** works great. my buddy uses it for his oil pan gasket on his 13b, and if u know anything about rotary gaskets/seals youll understand.</TD></TR></TABLE>
My 13b leaked like a loose *****... now she's blown up
Old Jul 1, 2007 | 02:07 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (G-stack double R)
Don't use Hondabond...use Honda Ultra Flange Sealant...it's what we use on for oil pans on cars that don't take gaskets
Old Jul 2, 2007 | 03:19 AM
MugenHonda's Avatar
Default Re: (Evs-One)
Bro, I work on cars, I know.
The only way permatex works is if you have the surfaces clean and have all the bolts at the same torque, which then even when it hardens up, you can flick it off like rubber. Hondabond is actually different type of sealant, and lasts way longer.
How does every toyota and honda use gasket type oil pan gaskets and at least last a good 60-100k before needing replacement?
You get what you pay more, permatex in my mind should only be used as assurance when there is a gasket as well.
journeyquest
Sep 3, 2010 12:39 AM
Soon2bH2b
Mar 7, 2008 04:09 PM
BlueLude84
Feb 4, 2007 11:14 AM
stumpyf4
May 21, 2004 01:43 PM
Btothe3rdDegree
Aug 20, 2003 06:26 PM
