car wont start
Old Jun 28, 2007 | 06:03 PM
crxpwr1's Avatar
Default car wont start
I have a b16a in my crx...I also have the battery relocated...I got a new battery and a good alternator because I got it tested..all my wiring is good now it will turn over and wont crank I charged the battery to 100% and it still wont crank any suggestions?
Old Jun 28, 2007 | 06:24 PM
86crxintheworks's Avatar
Default Re: car wont start (crxpwr1)
is the car clicking when u turn it over?is ur main relay clicking?what does it sound like when u turn the key?
Old Jun 28, 2007 | 06:30 PM
crxpwr1's Avatar
Default Re: car wont start (86crxintheworks)
the clicking is coming from the starter...it sounds like my battery dont have enough juice when its on 100%
Old Jun 28, 2007 | 06:34 PM
abnaasefmb's Avatar
check voltage at the starter should be close to the same as the battery, if not, check the leads.
Old Jun 28, 2007 | 06:39 PM
crxpwr1's Avatar
Default Re: car wont start (abnaasefmb)
I have there the same..that was one of the first things I checked
Old Jun 28, 2007 | 06:43 PM
can u hear ur main relay click and the fuel pump prime?
Old Jun 28, 2007 | 06:44 PM
try taking a screw driver and touching both the wires on the starter 2gether and c what it does..
Old Jun 28, 2007 | 06:47 PM
crxpwr1's Avatar
yes I hear those activate and I think my friend that was hear did the screwdriver thing and it sparked but i dont know if thats what he did
Old Jun 28, 2007 | 06:50 PM
it will spark if they arnt touched rite.try it and make sure they are both touched good and at the same time
Old Jun 28, 2007 | 06:53 PM
crxpwr1's Avatar
it should turn it over right?
Old Jun 28, 2007 | 07:01 PM
yea
Old Jun 28, 2007 | 07:13 PM
crxpwr1's Avatar
alright do you have any other suggestions so I can do them tomorrow when I get up
Old Jun 28, 2007 | 07:34 PM
try this and post what the car does..il check 2maro morning at work
Old Jun 28, 2007 | 09:25 PM
abnaasefmb's Avatar
Did you just bolt the ground for the battery down in the trunk somewhere?
Old Jun 29, 2007 | 10:30 AM
crxpwr1's Avatar
yea I drilled a hole...but I went and got my starter tested and it failed so I got another one and it still wont crank...its starting to **** me off
Old Jun 29, 2007 | 10:52 AM
BOWXDOWN2's Avatar
I had the same issue in my car, it was the fuel pump. As soon as I changed the fuel pump it started right up and never had a problem since.
Old Jun 29, 2007 | 10:55 AM
crxpwr1's Avatar
Default Re: car wont start (BOWXDOWN2)
i hear it prime
Old Jun 29, 2007 | 05:24 PM
abnaasefmb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">check voltage at the starter should be close to the same as the battery, if not, check the leads.</TD></TR></TABLE>
Old Jun 30, 2007 | 09:03 AM
crxpwr1's Avatar
I found the problem I forgot to scrap the paint where I grounded my wire at coming from the starter...cranks up everytime
poprocksncoke
Jan 28, 2017 04:56 AM
95-del-sol
Jul 15, 2013 08:12 PM
inaety
Jun 24, 2011 12:57 AM
ek coupe
10
Mar 5, 2010 05:02 PM
bo0sted
Mar 20, 2005 07:56 PM
