knock sensor boot
Old Jun 28, 2007 | 04:04 PM
burntheblobs's Avatar
Default knock sensor boot
I'm trying to get my knock sensor plugged in on my 93 civic lx. The sensor is in the block but the connector is dissconnected. The boot seems like it makes the connector impossible to get on. Any suggestions?
Old Jun 28, 2007 | 04:14 PM
Reynolds's Avatar
Default Re: knock sensor boot (burntheblobs)
Trying to get it on? break that dryrotted boot up into lil' pieces and trow it away... Then you will be able to plug it in... If you are refering to the one wire sensor on the back of the block...
Old Jun 28, 2007 | 04:21 PM
slowcivic2k's Avatar
Default Re: knock sensor boot (Reynolds)
Thats not the knock sensor, its the oil pressure sending unit plug, the knock sensor has a two pin plastic gray plug with one wire in it....
take a touch of oil to the inside of the boot.
quicky_hatch12
Oct 7, 2005 11:59 AM
93si-hybrid
Jul 15, 2004 01:09 PM
Atheist
Apr 18, 2004 10:14 AM
T_Rex
Feb 3, 2003 07:43 PM
