whats wrong with my b16 hatch help me
idles @ 2000rpm then vtec kicks in around 7000 and is supposed to kick in @ 5600 also breaks up around 2500 to 4000 rpm sometimes help
Is your car throwing any CEL codes? if so, find out what they are then have that fixed. If not check the IACV, or FITV have both clean out with brake cleaner for the idle issue. Check the vtec solenoid, for leaks or bad connection same with the vtec pressure sensor for the vtec crossover.
