Craftsman Valve Spring Compressor --- Can't get it to work. Any tips ?
Old Jun 27, 2007 | 10:43 AM
street_ride14's Avatar
Default Craftsman Valve Spring Compressor --- Can't get it to work. Any tips ?
Any techniques on how to use this tool? I want to upgrade my valves, went out to Sears to buy this tool, but it doesn't quite fit in properly. Any ideas on how to make this work? h22 cylinder head
Which valve spring compressor will you recommend ? I don't like the price of a Snap-On, so anything other than that ? Which did you use ?
Old Jun 27, 2007 | 01:12 PM
Giant_Bean's Avatar
Default Re: Craftsman Valve Spring Compressor --- Can't get it to work. Any tips ? (street_ride14)
I like the looks of this one: http://cgi.ebay.com/ebaymotors...wItem
haven't tried it myself, so I don't know how well it actually works, but seems to be pretty straightforward.
Old Jun 27, 2007 | 07:43 PM
Lubo_25's Avatar
get a nice wrap around style for installing springs...snap on makes a deadly one but at a cost and its fully adjustable for any head size or you can make your own all you need is the angle of the valves... good luck
Old Jun 28, 2007 | 09:47 AM
TruNinja619's Avatar
if all else fails here's what i do...
put the cylinder you're replacing the valves on the compression stroke.. inject air into that cylinder and take a 19mm deep socket (w/ a short extension on the socket).. place the socket on top of the valve.... and use a hammer to strike the extension to get the valve keepers out.. might have to give a few blows at it...
install the spring....
then when you're ready to install the valve kepers... you use a tool like this for the keepers..
Old Jun 28, 2007 | 12:51 PM
TOP END MS's Avatar
You usually have to remove the head from the block i beleive.
Old Jun 29, 2007 | 08:45 PM
Jago's Avatar
Default Re: (TOP END MS)
that won't work on dohc motor its meant for sohc
Old Jun 29, 2007 | 09:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOP END MS &raquo;</TD></TR><TR><TD CLASS="quote">You usually have to remove the head from the block i beleive.</TD></TR></TABLE>
not necessarily if you're replacing valve springs... like i said earlier.. if you have an air compressor and the adapter from a compression tester that screws onto the spark plug hole... inject air into the cylinder you're replacing the valve springs (on the compression stroke).. and you can do it from there... but thats like a last resort thing.. lol.. i do recommend taking the head out..
Old Jun 30, 2007 | 03:24 AM
Default Re: (TruNinja619)
An update ... My head is already removed from the block. I went ahead and order the tool that the guy was selling from eBay. By main concern now is ... On the title he says made for b16, b18, and h22 heads ... do these really have the same valve to head angles ?? He just mentions h22 in the title and nowhere else in the auction.
Old Jun 30, 2007 | 04:44 AM
mattsnooz's Avatar
Default Re: (street_ride14)
two types of valve compressors. Some are for with head out and some can be used with head still in though. The crapsman one you got looks like it can be used with head still on block!
Old Jun 30, 2007 | 07:03 AM
PrecisionH23a's Avatar
Go with one like this:
Old Jun 30, 2007 | 07:16 AM
v4lu3s's Avatar
RTFM
Default Re: Craftsman Valve Spring Compressor --- Can't get it to work. Any tips ? (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">Go with one like this:
those KICK ***!!!!!!!!!!!
Old Jun 30, 2007 | 07:29 AM
117's Avatar
117
Default Re: Craftsman Valve Spring Compressor --- Can't get it to work. Any tips ? (Giant_Bean)
I've got one, and it works quite nicely.
The type posted by PrecisionH23a works nicely as well, but you have to use one hand to keep pressure on the retainer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Giant_Bean &raquo;</TD></TR><TR><TD CLASS="quote">I like the looks of this one: http://cgi.ebay.com/ebaymotors...wItem
haven't tried it myself, so I don't know how well it actually works, but seems to be pretty straightforward. </TD></TR></TABLE>
Old Jun 30, 2007 | 07:43 AM
LudeBehavi0r's Avatar
Mgags7 has the one Precision posted and it works great, provided u have someone to hold the compressor and someone to pull the retainers. Trying to use that tool by urself and pull retainers would be an f'in task.
Old Jun 30, 2007 | 07:48 AM
Default Re: (LudeBehavi0r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeBehavi0r &raquo;</TD></TR><TR><TD CLASS="quote">Mgags7 has the one Precision posted and it works great, provided u have someone to hold the compressor and someone to pull the retainers. Trying to use that tool by urself and pull retainers would be an f'in task.</TD></TR></TABLE>
If you don't have a compressor, get a rope and put it down into the cylinder. Then rotate to TDC on that cylinder and the rope will hold the valves from dropping.
Old Jun 30, 2007 | 11:54 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_ride14 &raquo;</TD></TR><TR><TD CLASS="quote">
You get what you pay for..."There is a diffrence"
gucci mane
Dec 12, 2013 07:48 PM
boostd92
Sep 12, 2008 05:40 PM
93SIRII
May 2, 2005 08:43 PM
93b16
Feb 2, 2005 04:47 AM
743power
Sep 16, 2004 04:29 AM
