Piston Prep Resources
Old Jun 27, 2007 | 07:39 AM
HybridKOOP's Avatar
Default Piston Prep Resources
Does anyone here have any good resources related to piston prep before assembly? I'd like to educate myself about deburring, polished vs. roughed, coatings, etc.
I'm running shelf CP's and would like to add any insurance to them now that I can, before I assemble the block.
THANKS.
Old Jun 27, 2007 | 07:51 AM
Boostfed's Avatar
New User
Default Re: Piston Prep Resources (HybridKOOP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridKOOP &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone here have any good resources related to piston prep before assembly? I'd like to educate myself about deburring, polished vs. roughed, coatings, etc.
THANKS.</TD></TR></TABLE>
Theres a Chinese guy on this Forum that is very knowledgeable on that BUT he doesn't speak English. Louis you better get your English to Chinese Translator out! lol
Old Jun 27, 2007 | 07:52 AM
HybridKOOP's Avatar
Default Re: Piston Prep Resources (Boostfed.com)
Terry, you're worse than my fiance!
Old Jun 27, 2007 | 12:14 PM
tepid1's Avatar
Cp's are pretty clean off the shelf.... at least mine were. I touched them up a bit just for added insurance though.
It's tough to see in the pics, but you get the idea. I went around all the corners and edges.
Old Jun 28, 2007 | 05:55 AM
HybridKOOP's Avatar
Default Re: Piston Prep Resources (tepid1)
Chris, your motor is 81MM?!
Old Jun 28, 2007 | 08:35 AM
tepid1's Avatar
No.
Old Jun 28, 2007 | 08:43 AM
HybridKOOP's Avatar
Well it's under 83.0, correct?
Old Jun 28, 2007 | 08:56 AM
HybridKOOP's Avatar
Default Re: Piston Prep Resources (rota92)
My vote is 81.5
But, yes, vTAK for sure.
TheWickedOne's Avatar
those sleeves looks monstrous.. Looks like a Benson (Darton) sleeve..
Old Jun 28, 2007 | 08:57 AM
HybridKOOP's Avatar
Default Re: (TheWickedOne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheWickedOne &raquo;</TD></TR><TR><TD CLASS="quote">those sleeves looks monstrous.. Looks like a Benson (Darton) sleeve..</TD></TR></TABLE>
Hey man, how is the rebuild going? Spoke to Tom a few nights ago... hit me up on PM.
Old Jun 28, 2007 | 09:55 AM
Default Re: (HybridKOOP)
Hey man, how is the rebuild going? Spoke to Tom a few nights ago... hit me up on PM.</TD></TR></TABLE>
Good man, some odds and ends .. Like brakes.. etc.. Just need to find some time.
-G
Old Jun 28, 2007 | 10:00 AM
tepid1's Avatar
Correct. 81.5mm.
They are Benson sleeves as well.
All CP pistons 81.00 through 83.00 have the reliefs cut now.
Old Jun 28, 2007 | 10:23 AM
HybridKOOP's Avatar
83MM doesn't have them clipped out.
I think it's 82.5MM and down.
Old Jun 28, 2007 | 10:32 AM
tepid1's Avatar
Nope.... 83's and down....
Trust me on this one. You must have an older version if you still have reliefs.
Old Jun 28, 2007 | 11:05 AM
HybridKOOP's Avatar
Incorrect. Never made an 83MM with trimmed reliefs. Only 82MM and smaller.
CP: (949) 567-9000
Old Jun 28, 2007 | 11:35 AM
tony1's Avatar
oooohhhh, take that! lol
Old Jun 28, 2007 | 11:53 AM
HybridKOOP's Avatar
Default Re: Piston Prep Resources (tony1)
LOL. He figured out that they were a custom set thru CP.
Old Jun 28, 2007 | 11:58 AM
tepid1's Avatar
Right. They were a modified shelf piston. I didn't relize that. Oops.
Hahaha
Old Jun 28, 2007 | 04:40 PM
BLK JDM's Avatar
Who modified the reliefs of those 83mm pistons? Also I wonder why the do not make reliefs on the larger MM bores??
Maybe some of you engineers can lead me to an answer or give me answer.
Old Jun 28, 2007 | 04:43 PM
Boostfed's Avatar
New User
Default Re: Piston Prep Resources (BLK JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLK JDM &raquo;</TD></TR><TR><TD CLASS="quote">Who modified the reliefs of those 83mm pistons? Also I wonder why the do not make reliefs on the larger MM bores??
Maybe some of you engineers can lead me to an answer or give me answer.</TD></TR></TABLE>
I know I just got some Custom Wiseco Pistons through RLZ Engineering and my valve reliefs are cut. I was curious when I saw this.
Old Jun 28, 2007 | 05:46 PM
tepid1's Avatar
CP modified them.
It's not necessary on the larger bores because there is plenty of meat on outter edge of the valve relief.
Old Jun 28, 2007 | 06:07 PM
ninesecrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tepid1 &raquo;</TD></TR><TR><TD CLASS="quote">CP modified them.
It's not necessary on the larger bores because there is plenty of meat on outter edge of the valve relief.</TD></TR></TABLE>
Old Jun 28, 2007 | 06:11 PM
.RTErnie's Avatar
Default Re: Piston Prep Resources (ninesecrx)
I took a forged piston that was damaged and went around with my tig welder and just started seeing how much heat it took to make things melt. The EASIEST place to get flow (melt) was right where the valve relief met the cylinder wall
RS-2
Welding / Fabrication
Apr 29, 2008 05:28 PM
r3v da t3g
Oct 30, 2007 04:50 PM
black99x
15
Aug 10, 2006 03:06 PM
MAPU
Mar 4, 2006 09:51 PM
Boostage
Jun 9, 2005 07:44 AM
