Del sol B16 into EG?
Correct me If I'm wrong but does the Del sol B16 swap directly into the EG? what about the shift linkage? Motor Mounts? I've tried searching and have not really found direct answers. What all would I need to complete this swap? Thanks in advance.
i have a del sol b16 in my EG and its WAY to slow.
i got the car with the swap already done so i dont know what all they had to do.sorry i cant answer you question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Da1andonlyJinx »</TD></TR><TR><TD CLASS="quote">Correct me If I'm wrong but does the Del sol B16 swap directly into the EG? what about the shift linkage? Motor Mounts? I've tried searching and have not really found direct answers. What all would I need to complete this swap? Thanks in advance. </TD></TR></TABLE>
http://www.c-speedracing.com/h...p.php
what's the difference?
same block cept shorter deck height, same trans, same sensors....
i'd be curious to know if there is a difference because i've always seen them treated the same...
My question was not about the the b18c swap it was based on the B16 OUT OF THE DEL SOL if the linkage out of the del sol would work in my EG. That was the question, so thank you egsleepercivic for straight up answering my question.
CHINKA
Mar 16, 2007 10:16 PM
quik sol
Jan 17, 2005 07:33 PM
