Help with sub please
Old Jun 26, 2007 | 11:55 PM
FW_EJ8's Avatar
Default Help with sub please
I need help please..
Okay Im running a LOC because im using the stock head unit. I spliced it into the rear speakers. Now when i plug the RCA in all the way, the sub stops working. But when the RCA is just touching without the ground, the sub works. So what is the problem?
Old Jun 27, 2007 | 06:44 AM
jz98ctr's Avatar
Default Re: Help with sub please (TW_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TW_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">I need help please..
Okay Im running a LOC because im using the stock head unit. I spliced it into the rear speakers. Now when i plug the RCA in all the way, the sub stops working. But when the RCA is just touching without the ground, the sub works. So what is the problem?</TD></TR></TABLE>
NEED MORE INFO
first things first....year, make, and model of car!
second...make and model of the amp
third...make and model of the loc
lastly the way you have everything hooked up
are you having trouble with the left or right RCA channel? try to describe IN DETAIL as much as you possibly can so we can help you better and quicker and give you a more concise answer to your questions.
Old Jun 27, 2007 | 08:29 AM
FW_EJ8's Avatar
Default Re: Help with sub please (jz98ctr)
Its a 1997 Honda Civic Ex
The amp is Rockford Fosgate AS2
The LOC is a 2 channel Blue Wave
The LOC is spliced into the rear speakers of the car, so in the trunk.
When we plug the RCA(the amp to the LOC) in all the way the sub does not work. But when the tip of the RCA is touching the LOC the sub works.
Here are some pics that i hope will help..
Modified by TW_EJ8 at 9:40 AM 6/27/2007
Old Jun 27, 2007 | 10:32 AM
FW_EJ8's Avatar
Nevermind, redid the splicing into the rear speakers and it works fine. Thanks for the help though jz98ctr
dragstripboy
Audio / Security / Video
May 20, 2005 10:28 PM
94AcuraIntegraGsr
Apr 15, 2005 10:53 PM
joek84
Sep 29, 2003 05:17 PM
SoCal ITR
Jul 3, 2003 07:56 PM
PurplePill
May 22, 2003 04:25 PM
